VHDL 4 input 1 output MUX
gammaman
Joined Feb 14, 2009
29
I am very new to VHDL and I am trying to code a MUX, I am close but need a little help
Rich (BB code):
Library ieee;
Use ieee.std_logic_1164.all;
Entity Mux is
   Port(
       D : in std_logic_vector(4 downto 0);
       Y : out std_logic_vector(1 downto 0));
End Mux;
Architecture Joe_Structure of Mux is
Begin
   with D select
   Y<= "I0" when "00",
       "I1" when "01",
       "I2" when "10",
       "I3" when "11";
End Joe_Structure;
silvrstring
Joined Mar 27, 2008
159
'D' is not your select. 'D' is only the signal inputs. You need to add another 'in' variable for the select. In your Entity, put 'S' where 'Y' is, and make it an 'in' instead of 'out.' You will still need 'Y' for your 'out,' though. But Y is not a vector. Maybe "std_logic".
In your Architecture, 'S' is going to be your select, not 'D.'
Also, I think your y<= "I0" when "00" etc., statements should be y<= D(0) when "00" and so on.
Try finishing with "'0' when others;"
Not sure what version of Quartus you're using, but you might also want to download the latest trial. It has less problems.
silvrstring
Joined Mar 27, 2008
159
By the way, the example I'm looking at is from an older text. Some things are different with Quartus now. If there's still a problem, it's probably going to be the "I0" thing versus using D(0)...
If you try both and there's still a problem, you probably want to try different data types in your Entity. Let me know how it goes.
gammaman
Joined Feb 14, 2009
29
Yeah when I compiled in Quartus II the only errors I got delt with the I0 to I3, it said I could not use the letter I, but I do not know how else to represent it.
gammaman
Joined Feb 14, 2009
29
No, I get the same error as before, it says that the letter "D" is not allowed.
Error (10315): VHDL syntax error at Mux.vhd(14,15,16,17): object with std_logic type, cannot contain character 'D'
veritas
Joined Feb 7, 2008
167
In your example, you have "I0" like that in quotes. Anything in quotes is taken as a literal string, usually of binary. If you have a variable D of type std_logic_vector, then you can access the individual bits of D with D(index).
silvrstring
Joined Mar 27, 2008
159
gammaman,
This example comes directly out of the book. I compiled it, and it came back okay.
Try it like this. If it still doesn't compile, you might want to check for updates or download the latest version of Quartus from Altera.com
Library ieee;
Library ieee;
Entity Mux is
Port(
S : in std_logic_vector(1 downto 0);
Y : out std_logic);
End Mux;
Begin
with S select
Y<= D(0) when "00",
D(1) when "01",
D(2) when "10",
D(3) when "11";
End Joe_Structure;
