Notice I said: people. I did not say: people in industry.I hope people in the industry have more sense and know how.
I couldn't agree more.People without training shouldn’t be messing with high voltage. Accidents happen even with training. Fluke will not protect you from ignorance.
Yes, I've just had some time off to pop some fresh cells in. I brought my Elenco M-1700 (hey- it came with an associates degree at a tech school several years ago) from work where It collects dust, so I have some kind of reference at least. Just testing some small solar panels for open circuit voltage and current. The Uni-T still measuring low mA readings and is more accurate with the full amp jack and setting. Going to take it apart tonight and clean as you and rsjsouza suggested.Go ahead and change the batteries and see if that solves the problem. My best guess is that they selection dial switch has worn contacts. A drop f squirt of contact cleaner might restore good operation.
I would say it's better in some ways than my first Fluke. Sometimes it's really all you need.Don’t even call the free Harbor Freight one a multimeter or put it in the same category as the others. I have about 5 of those and they’re good for the 9V battery. If you paid anything for one it’s too much.
He probably plugged the probe at the unfused 10A input, which would obliterate the meter regardless of the range it was set (it has a dead short between the COM and the 10A input).My son stuck a free HF meter in a wall socket and blew it up scaring us. He was ok but the meter died violently. I was scratching my head looking at the CAT II 1kv rating. I’m sure he had it in the wrong setting.
Hard to say what your son was doing with a meter and wall socket. Without supervision and education, a few things could have happened. The meter's high current shunt is not fused. Connecting the leads to the high current shunt and proceeding to probe the AC could be a problem. The low current input is shared with the voltage input. Even with the leads connected properly, obviously selecting the current mode would be a bad idea. It is fused but the fuse type varies meter to meter.Joe keep up the good work.
Never had an issue with a fluke other than not knowing that the 113 only reads up to 60k ohms or my Sperry. I have no issues probing for high plate voltage on tube circuitry.
This Thsinde just boggles my mind. It’s a little slow to settle but built well and useful so far.
I'm not so sure it would obliterate the meter. Something would open up eventually. Maybe the CB.He probably plugged the probe at the unfused 10A input, which would obliterate the meter regardless of the range it was set (it has a dead short between the COM and the 10A input).
Joe, hyperbole was added for effect.I'm not so sure it would obliterate the meter. Something would open up eventually. Maybe the CB.
I ran that test with the leads and I can believe the leads in some cases would open up before the meter.
I posted a while ago a similar video - perhaps that is what you remember. A Brazilian talk show presenter was trying to show how to use a "Harbor Freight-like" DMM when she was trying to measure a 220VAC outlet. With a poor contact, she thought about moving the range switch and suddenly a small "bang" was heard - perhaps due to the V/Ω/mA shared input.There was a video floating around of a TV show where they were selling products. The person demonstrating the meter plugs it into the wall socket and proceeds to turn the knob to the current setting. They got a bit of a bang from it.
Yes, with such broad audience venue like Youtube, one cannot be too cautious in providing answers to questions. In replies on my channel, I tend to try to set the stage before actually answering the question - the issue is that the replies end up becoming too extensive.I suspect that is the same video. I think the first time I saw it was on Reddit.
I attempted to run one of the free meters while in it's highest voltage setting across my half cycle line simulator. This obviously exceeds the 20J I mentioned earlier. If you read the comments, someone had asked "You had it in the 750V mode but what did you run through it ?" and I responded with 4KV. After being on Youtube for a while, I think that was a bad answer as there is a good chance the person asking wouldn't have any grasp of the waveforms being applied. They may have very well went away thinking I hit the meter with 4KV DC. I've had people write me that I was connecting them directly to a capacitor bank. They of course don't understand that the waveshape is present even with no load and that the generator itself absorbs the excess energy which is converted to heat in the output network.
| Thread starter | Similar threads | Forum | Replies | Date |
| R | Just having a bit of a current control problem. | Power Electronics | 45 | |
| M | Crossing within differential pair problem | PCB Layout , EDA & Simulations | 17 | |
| S | Boss DM-2 PCB problem | PCB Layout , EDA & Simulations | 9 | |
Filter problem | Analog & Mixed-Signal Design | 8 | |
| J | Help Drawing Circuit for Problem. | Homework Help | 15 |
