Thank youCan you highlight the part of the datasheet that you do not understand?
What I meant by the simple explanation was that, for example, if I put the voltmeter probes on the gate and drain or gate and source pins, what is the allowed voltage?
Or is this measurement wrong and I should put the probes on the MOSFET and GRAND or + pins?
I didn't understand this from Dataasht and first I have to see if the MOSFET condition is standard or not and then go to the next possibilities
Thank you for the simple explanation
