uc3843 buck-boost
Ian0
Joined Aug 7, 2020
13,158
I think it needs a larger value of C9, say 10nF, and a resistor, say 100k, between the pot wiper and the feedback pin.
mrh586
Joined Dec 5, 2021
90
Your schematic is still wrong. Review post #73
Which part do you mean?
If you mean the potentiometer, I explained in the reposted post that in the real circuit, it didn't work that way at all.
If there is another part, please explain
mrh586
Joined Dec 5, 2021
90
I tested, there was no change
It's interesting, I used two software to simulate the circuits (both Buck and Buck Boost) and tested different values.
But variable resistance does not work in both software
This circuit has a secret
eetech00
Joined Jun 8, 2013
4,709
The variable resistor should have worked, so you probably wired it wrong.
You reconfigured the circuit to a boost topology. The FB network should resolve to 2.5v at the FB pin when the output is at the target voltage. So you need to stop guessing and recalculate the resistance values accordingly.
mrh586
Joined Dec 5, 2021
90
Thanks for your tips
I checked it several times, nothing was wrong
In boost mode, the circuit is simpler and I can find its fault more easily
The problem is when the load is placed on the circuit, in the no load state everything works perfectly
When the load is placed on the circuit, the circuit does not work properly as I explained earlier
eetech00
Joined Jun 8, 2013
4,709
What is the input voltage and What is the target output voltage and current?
What are you using for a load , and what is the load resistance?
Check the Inductor DCR. What shockley diode are you using?
mrh586
Joined Dec 5, 2021
90
The input voltage has been tested from 18 to 27 volts (15 amps).
The output voltage I need is from 5 to 50 volts.
In buck mode, I don't need more than 15 amps.(Boost 8 amps).
DC motor,Lamp,Battry,Resistor
In all of these the circuit operation is the same
I dont get it
Do you mean inductance?
MBR30100CT
mrh586
Joined Dec 5, 2021
90
What is "MOSFET protection"?
I have read about it. Is my problem not related to it?
Reverse polarity or overvoltage or...
Please look at the attached pictures
eetech00
Joined Jun 8, 2013
4,709
I dont get it
No...I mean DCR (DC resistance). But the inductance would be good to know also.
Any component in series with load has to pass the current delivered to the load.
It may be one of the components is limiting the required current.
mrh586
Joined Dec 5, 2021
90
Do you mean the same resistance value that the LCR meter shows?
mrh586
Joined Dec 5, 2021
90
What the LCR meter showed was 0.2 ohms
mrh586
Joined Dec 5, 2021
90
mrh586
Joined Dec 5, 2021
90
No, further down - last but one item on page 8 "Operating supply current 17mA max"
Output current 63nC x 95kHz = 6mA
(30V - 12V)/(6mA+17mA+3mA) = 680Ω ½W
I have a question
According to your formula to calculate the resistance of IC pin 7, at 12V voltage without zener, the resistance should be 460 ohms, but in the schematic it is 4.7 ohms.
Is there another formula for calculating this resistance without a zener?
Ian0
Joined Aug 7, 2020
13,158
I bought an oscilloscope
If possible, tell me what to do now
First, have a look at the clock waveform on pin 4. When you've got that nice and clear on the screen, you know you have the timebase set correctly.
Then have a look at the waveform on pin 6 (the gate drive waveform), which should be a rectangular wave of about 12V amplitude.
If everything looks OK so far, look at the waveform on the MOSFET drain, screenshot it, and post it for us all to discuss (i.e. argue about)
mrh586
Joined Dec 5, 2021
90
Thank you
The waveforms of pin 4 and 6 and drain should be taken under load or without load?
Ian0
Joined Aug 7, 2020
13,158
Pin 4 should not change with the load.
Pin 6 and the MOSFET drain will convey useful information both with and without the load.
