Thank you very much to everyoneThat's Micrometals #26, or a copy thereof. It's iron powder, not ferrite, and it is exactly what you need for a SEPIC converter. From your previous posts, if it is 40mm outside diameter than it is a T157-26
https://datasheets.micrometals.com/T157-26-DataSheet.pdf
It has a permeance of 100nH, so 10 turns will give you 10uH, which is WAY too small for 95kHz.
You haven't specified the output power, but 500uH is probably more like what you need.
Also, do you have the two windings connected in the correct phase?
I learned a lot of information
I bought an LCR meter
It will arrive in a day or two
I can probably speak more precisely with it
I tried the circuit with two separate cores, I wound the big core myself and bought the other one ready-made, and in both cases it was exactly the same problem.
Both cores had two coils
I will report the exact value of both as soon as the LCR meter arrives
Thankful
