Fly back converter Design using UC3843
Balaji N
Joined Aug 28, 2023
I am designing a offline power supply which will 24V as output with 2.5A. I found UC3843 as better option. I used TI we bench tool to design my power supply. This is the schematic I got from it. The given transformer design, I given to one manufacturer and I got a transformer. I rigged up the circuit as it mentioned. But in this I am getting three Issues
1) Audible noise across the transformer.
2) Sometimes(randomly) restarts while I am connecting 1A load.
3) Small ripples present in output when there is no load(I made AC coupling so we can see the signal clearly and we can enlarge).
Ian0
Joined Aug 7, 2020
13,279
Have a look at the power supply to the UC3843. You may find that it is going in and out of UVLO.
What is the DC output voltage?
Balaji N
Joined Aug 28, 2023
I am getting 24.7V output voltage (Here I have used AC coupling to show the ripple, with that I can change volt/div, so it is enlarged).
UVLO happening at 7.8V around. And the ripple problem happens during the no load operation
Ian0
Joined Aug 7, 2020
13,279
400mV ripple isn't bad for a 24V supply on no-load, but if there are not problems elsewhere, it does indicate some instability in the feedback loop.
Have a look at the voltage on the emitter of the optoisolator, the COMP pin of the 3843 and the output pin of the TL431 to see if there is a similar waveform. Did you use the specified optoisolator?
Have you read SLUP340? The section on Isolated feedback with optocoupler is relevant
