building my own uc3843 boost converter
Momentory
Joined Sep 4, 2022
101
I am trying to make a boost converter using uc3843 with the following
- the input voltage = 12v
- the input current = 4A
- the output i want = range 150v to 235v
- the current output = 0.5A
i will use mosfet irf840 and diode UF4007
did did my design according to texas instrument pdf for boost converter
https://www.ti.com/lit/an/slva372d/slva372d.pdf
calculated :
- max duty cycle = 1- (V in min / V out max)* η
i assumed η = 80%
- I switch = I coil = I diode = ΔI/2 + I out max/ 1- D
(ΔI/2 = I load min = 10% of the I max = 0.05A)
inductor (L) = V in * (V out max - V in min) / ΔI*Fs*V out)
Fs = 100 KHz
ΔI = 2* I load min
i add R7 to the schematic just to make the circuit CCM boost converter ( i am not sure about its value yet!)
what do you think about this boost converter will work?
Papabravo
Joined Feb 24, 2006
22,111
A boost converter with that boost ratio will be impractical and difficult to control. A typical design would be limited to a boost ratio of 5-6 and you are far in excess of that.
On top of that your input power is:
12V * 4A = 48 Watts
Output power is:
150V @ 0.5 A = 75 Watts
If you can make this happen, you will win a Nobel prize.
I'm going to hazard a guess and say this will NOT be happening.
Momentory
Joined Sep 4, 2022
101
12V * 4A = 48 Watts
Output power is:
You are right, i do not know how i ignored this!!
I will try to increase the input to 24v - 5A
