Trying to use MCP4261, few questions need help
LAOADAM
Joined Nov 21, 2018
956
Need detail explanation about:
1. SHDN pin12 and sketch config, how to ignore SHDN cause of only one piece?
2. same as above of the CS pin1?
3. how to wiring wp pin11?
TeeKay6
Joined Apr 20, 2019
573
What parts of the Microchip datasheet do you not understand? (Pls give paragraph numbers & figure numbers.) Your question #1 is unclear to me; are you asking whether you can shut down only one half of a dual pot device?
DickCappels
Joined Aug 21, 2008
10,661
Tie SHDN high.
Ground this pin.
Tie this one high.
