So I am having some trouble building the circuit I had built in a sim, several to be exact, which all seemed to work the way I wanted them to. Now that I have built the circuit on a board, Im not getting the results expected. Checked wiring and and parts, things look ok. Odds are I have missed something in calculations and just not seeing it.
The goal is to power a little MP3 player that connected to the other side of an optocoupler, the optocoupler in this case is replaced by an LED on the right in the drawing below since it wasn't offered in the software; seeing as the side im connecting to is basically an IR led i believe I should be ok.
The device(LED) should be on for about 3-4 seconds t=(1.1*RC){R=330k and C=10uF}, then off.
Could anyone please check and see if i may have missed something in calculations or configuration?
Link to sim: https://everycircuit.com/circuit/6394445589905408
Diagram:
Diagram:
