Half Bridge Solid State Tesla Coil Trouble Shooting
AriK48
Joined Nov 7, 2025
33
Hi there,
I am currently working on a half bridge solid state tesla coil. I have built a class e sstc but I am having trouble with this one. Things seem to be going wrong at the gate pin of my mosfets for the half bridge. Lots of heat on mosfets and no spark at output. At the moment, I have a signal generator attached to the feedback antenna to give a 606kHz (~resonant frequency of the secondary coil + topload) signal.
Lots of ringing at MOSFET gate. I originally had 6.8ohm resistors, but I replaced them with higher value to suppress ringing but not much changed.
Also Faze lead should be phase lead. Idk what I was thinking:)
28,588
Hi there,
Please show us the actual circuit!!
It is quite likely that the output of the signal generator is not adequate. THAT has been my frequent experience. Most of the Tesla coil projects that I have seen that did not work suffered from not nearly enough feedback, so that they did not oscillate. The coupling between the drive coil and the feedback coil must not only be adequate, it must also be the correect phase relationship. THAT is often a serious challenge.
And now, a lot later, it is clear that the drive is not nearly adequate.
IN ADDITION, you need to actually have the circuit oscillate. Driving it close to resonance will not work. THAT means you need an adequate feedback winding on your coil setup. AND an adequate drive coil, with adequate coupling to the high voltage coil.
The circuit that works will look a lot like a power inverter for a big mobile radio transmitter power supply, except for the transformer.
ALSO, understand that there needs to be good power coupling between the drive winding and the feedback winding, and then that high voltage coil. AN they DO NEED to resonate at the same frequency.
28,588
On my second look, the first and very obvious flaw is the gate drive scheme for the two power mosfets. DANKO provides a better circuit in post #2. But even that does not provide for a solid "turn-off" of the power transistors.
EVERY ONE of the functional Tesla Coil circuits that I have seen had a power oscillator as the driver, not a logic driven amplifier. In addition, the diodes across the MOSFETS do a great job of damping the oscillations.
ALSO, I have NEVER seen a Tesla circuit with a half bridge driver. Not ever. So there must be a reason, although I am not going to dig for it.
One more consideration is that if those mosfets are getting hot, then they are both not being switched OFF adequately. There is no way that the upper transistor is being controlled. MOSFET control demands that the gate to source voltage is controlled, that is not able to happen with the upper mosfet. Please let us know what that 8 pin driver is supposed to be doing, I have not researched it at all.
AND, I do not like anything about that driver scheme WHAT ARE those IC devices that are supposed to be driving the mosfets?? I doubt very much that the mosfets are being switche off completely. In addition, that driver scheme does not look like one that I would use. Certainly I see quite a bit that does not look right, which is what I have stated above.
