Treadmill - Motor Control Board issue??
GeoB
Joined Oct 17, 2020
21
Thanks Max.
Do you know why the same issue is presenting on the new board?
I am trying to determine the root cause, I could try and troubleshoot the board but I imagine I will face the same problems unless i can fix the root cause.
I assume its these small diodes that i should be checking on the board?
and based on the schematic, which diode is the motor BEMF diode?
GeoB
Joined Oct 17, 2020
21
Thanks Max.
My board is a MC2100ELS-50W. The old board is labeled V1 and my new board is labeled Y2
GeoB
Joined Oct 17, 2020
21
Thanks Max!
any idea what would trigger these diodes failing?
i will go and test my board now and see what i get.
GeoB
Joined Oct 17, 2020
21
Hi Max, I checked the diodes, they are all good. i checked DI3, D14, D17.
I get a diode volt reading one way but not the other.
where else should be checking for this short? transistor?
not sure if it is relevant but I get 0 ohm resistance across the + and - of the DC terminals. (no motor attached, board is off the machine) i.e. when i set the multi meter to detect resistance, i get a continuous beep when touching the two terminals.
GeoB
Joined Oct 17, 2020
21
Hi Max,
I hope i have this right, but it looks like D3 and D6 has shorted on both the old and new board.
I can't find it on the schematic but its next to the tow relays on the opposite of the board to the 8pin panel cable.
I am getting 0.26V in both directions across the two diodes.
no idea if this is connected to initiating the start button on the op panel...?
30,674
I don't have a version of that board to compare to the three I have, there are at least 5 versions of this board.
Ensure those diodes are not across the coils of the relays, as you will not get a true reading.
The command you give to start, does it include the ramp angle motor?
GeoB
Joined Oct 17, 2020
21
Hi Max,
no I just press the start button, but you might be right, if the relays don't have anything to do with the belt motor then maybe its a false reading.
is my IGBT blown? i only get 0V readings, on my old board I get 0.8V readings.
and am i supposed to have a short between A+ and A-?
GeoB
Joined Oct 17, 2020
21
Hi Max,
surprisingly, on my old board i get a super high reading 60K ohms.
on my new board i get basically zero between A+ and A-, but there is a definite short(resistance) between the A+ and A- since it beeps on the meter when I use sound.
GeoB
Joined Oct 17, 2020
21
the board is new, if you are referring the material between the diode/IGBT and the heat sink then they look fine.
30,674
The first would be the BEMF diode, but you say you checked it as OK.
There is not much else that if shorted , that would show up as shorted M+/M- ?
There is C13 that may give close to that.
GeoB
Joined Oct 17, 2020
21
Hi Max, I took a pic of the energy board. I am wondering if the diode that is next to IGBT (both attaches to the heat sink) is the diode you are calling D13. On the board it is D15.
I checked the diode attached to the heat sink and whilst I get OL in ove direction, I only get 0V in the other. This is weird, I also only get 0V when I measure across the IGBT next to it. On my old board I measure 0.4V on the diode and 0.008 on the IGBT.
any help would be much appreciated. I can’t figure out why I have a short between M+ and M-
GeoB
Joined Oct 17, 2020
21
Hi Max,
not sure if i have this right but from the schematic you sent, I see 3 paths to a short where only one component has failed (see pic in previous post)
1. D13 failure
2. C17 failure (assumes the switch at Q2 is locked on or has also shorted)
3. C18 failure (assumes the switch at Q2 is locked on or has also shorted)
i could be way off, but is that logic accurate?
this M+/M- short just doesn't make sense. I get zero resistance.
n.b. there is some flux liquid on the board (alot of it), but the board did work for 30 min before shorting, so not sure if that is at play here.
