MC2100 treadmill motor control circuit #4
Manuel Maldonado
Joined Mar 5, 2026
7
MaxHeadRoom
Joined Jul 18, 2013
30,885
Which resistor i.e. designation R?
D5 Diode , why do you suspect the one shown, any 10a rated one should work, the one shown looks OK ??
Manuel Maldonado
Joined Mar 5, 2026
7
Thanks for taking the time to answer my question,
Pink resistor(R49)i push it to hard got broken, and (D5) is measuring both ends, and resistor R46 any replacement please thanks,
MaxHeadRoom
Joined Jul 18, 2013
30,885
Did not see any pictures of the diode, how does it check with a meter?
That section is one board thatd has a SMPS (Switch mode Power Supply.
That section is known for problems, the diode is the 12v DC output source.
You really need to bench test the board and take voltage readings of that section.
The value of R49 18ohms ( brown grey blk)
