MC2100ELS-50W Treadmill Controller
Terrasi
Joined Jan 28, 2026
Buongiorno, avrei un problema con questa scheda, praticamente ho sostituito mosftet, diodo e scr.
Praticamente alimentandola da Banco l’elettronica funziona, quando la vado a collegare al Tapis roulant, mi salta il differenziale.
volevo sapere sul dissipatore in alluminio, l’SCR è provvisto di dissipatore isolante dall’alluminio?
Allego foto della scheda
Mod translation.
Good morning, I have a problem with this board. I basically replaced the MOSFET, diode, and SCR.
When I power it from the bench, the electronics work fine. However, when I connect it to the treadmill, the differential trips.
I wanted to know about the aluminum heatsink. Does the SCR have a heatsink that isolates it from the aluminum?
I'm attaching a photo of the board.
Terrasi
Joined Jan 28, 2026
There is no way to try it, without going to connect it, just card? Simulate only the engine output, adjust the pwm? And if there is an electrical diagram that can be executed on the board. Thank you
MaxHeadRoom
Joined Jul 18, 2013
30,813
On the bench, the MC2100 board requires a 20Hz PWM into pin 4 of HD2.
There are a few circuits out there, and also a very cheap PMW controller with digital display sold on line.
I also made up some small ones using a pic micro.
Mod translation.
Can you help with the part number of those 8 pin pwm controller ics
