- Joined Jul 18, 2013
- 30,725
There are several post here showing the schematic, Such As
There are at least five versions of the board, however.
Thanks Max.
Do you know why the same issue is presenting on the new board?
I am trying to determine the root cause, I could try and troubleshoot the board but I imagine I will face the same problems unless i can fix the root cause.
I assume its these small diodes that i should be checking on the board?
and based on the schematic, which diode is the motor BEMF diode?
My board is a MC2100ELS-50W. The old board is labeled V1 and my new board is labeled Y2
