That would lower the input impedance below 1M, wouldn't it. Maybe to around 667K?I would suggest dropping the value of RPD1.
That'd create a LPF at 16kHz, wouldn't it? Not sure we want that per-se. Are you thinking to rid the audio of the oscillation noise with that?Try adding 10kΩ in series with the input followed by a 1nF capacitor to ground.
Are you referring to the power supply? It's there. 100nF right at Pin 8 of the op amp. You're right though, I didn't show it in the schematic. Didn't want to throw in more variables, but I can post a full schematic if that helps.I don't see any supply decoupling capacitors on your circuit diagram.
It would but curious if the noise is eliminated or reduced, start at 1M.That would lower the input impedance below 1M, wouldn't it. Maybe to around 667K?
I do have a scope. I'm guessing it has something to do with our layout. Not sure if this is too hard to see what's going on, but here's the circuit board:It would but curious if the noise is eliminated or reduced, start at 1M.
I have that circuit on my breadboard and see no noise even with RPD1 removed.
I see a path from IC6 pins 9 and 3 to pin 4 of IC5 along with the input jack. How long are those traces?
Do you have scope?
I only see that on pins 1, 2, 6, and 7. Not seeing that noise on the opamp's input pins (3 and 5).Now that you have found the signal on the output, can you find it on the input pins of the op-amp? If so , which pin? And is there some remnants of it on the supply?
Seems like the same noise witness earlier from the ECU.That made it worse.
That's connected to the Ground PlaneI don't see a track connecting to pin 4 (negative supply) of the op-amp.
Post #24. It's there.I don't see a track connecting to pin 4 (negative supply) of the op-amp.
Haven't yet. What's your thinking/theory on doing that? It'd lower the AC impedance seen by the guitar to about 667K instead of 1M.Did you try lowering the value of RPD1?
| Thread starter | Similar threads | Forum | Replies | Date |
| L | New EE student here — hoping to start writing and learning from this community ←(>▽<)ノ | General Science, Physics & Math | 11 | |
Crystal Ball Community Brainstorming | Sensor Design & Implementation | 11 |
