Technics SU-VX800 amplifier
35,113
We will take resistance measurements on the +V and -V supply.
Set your DMM to 20KΩ range.
To check the +V supply, connect BLACK probe to J401, RED probe to J403.
(You may have to lift R505, but let's see how it goes.)
[To check the -V supply, connect RED probe to J402, BLACK probe to J401.]
Correction:
To check the -V supply, connect RED probe to J401, BLACK probe to J402.
Install
IC402
Q416
Q426
Q430
Edit: wrong connection now corrected.
Marius83
Joined Dec 28, 2017
423
OK, let's see..
I see you have corrected.
Measured resistance,put DMM to 20K range:
Black to J401 and Red to J403: 14,17Ω
Then i lifted one leg of R505, and measured again: It got out of range.. open.
Red to J401 and Black to J402: Out of range... open
I actually got one thing wrong in post #242, Q426 tested OK earlier. But i did manage to drop it and i don't know were it went so i installed a new.
Installed:
New Q416
New Q426
Q430
IC402
I have many of IC402.. should i install a new one (?)
JoeJester
Joined Apr 26, 2005
4,390
Marius, I think the plan is to work our way back till you get all the components reinstalled ... the resistance tests at each stage of the game prior to the application of power. But I will let Mr Chips confirm that.
35,113
Correct. We will do resistance tests:
RED to J403, BLACK to J401
RED to J401, BLACK to J402
Next step is resolder R505 and install new R506.
Power up.
Measure voltage at
TP401 - 1
TP401 - 2
TP401 - 3
TP401 - 4
TP501 - 1
TP501 - 2
TP502 - 1
TP502 - 2
JoeJester
Joined Apr 26, 2005
4,390
My guess is that he meant 14.17kΩ.
I too have that hope. If it were the former, it would be best not to apply power. In fact the opposite power supply rail should read the same using the opposite or reverse connection. I don't think anyone wants to replicate the work already done.
MrChips, I only broke from our conversation mode because of the confusion and what would happen if it were the former (14.xx) vice the latter (14.xx k).
Marius83
Joined Dec 28, 2017
423
I understand
So i will now install
new IC402
Q401
Q405
new R506
resolder R505
And then power up, check for smoke and measure the voltages you listed.. ok?
35,113
As far as I can tell, the only way R401 and R402 can be blown is for IC401 and IC402 to be damaged.
To be on the safe side, remove IC401 and set aside.
Solder 8-pin socket and insert new RC4558P.
Marius83
Joined Dec 28, 2017
423
I finally got to do something here.
I have done some cleaning under the board, and I have now installed:
I actually got hold of some Sn/Pb solder it is a little better to use, i agree.
New IC402
Q401
Q405
new R506
resoldered R505
Soldered in socket and inserted new IC401 (RC4558P)
Some overview pictures of current situation
35,113
R517 looks discoloured or is that just the lighting in the photograph?
Install new
Q425, 2SA1123
Q427, 2SC3944 power transistor
Q429, 2SA1535 power transistor
Q402, 2SA1123
Q406, 2SC2631
Q408, 2SA1123
Marius83
Joined Dec 28, 2017
423
Install new
Q425, 2SA1123
Q402, 2SA1123
Q406, 2SC2631
Q408, 2SA1123
Yes, R517 is discoloured, because of R513 next to it has burned up twice or more.. hehe.
But i got curious and measured it.
Both R517 and R515 next to it, measures open circuit..:rolleyes:
I checked two other similar resistors on the other channel, (R566, R568) just to check that my meter was ok.
And they measure the correct resistance, so my meter was ok.
Then i installed:
new Q425
new Q427
new Q429
original measured ok Q402
new Q406
new Q408
Just some overview pictures of current situation again:
