C425 and C426 are removed and there is no solder issues. R506 has also been removed.With POWER OFF and unplugged, we will do some resistance checks.
At this point I assume C425 and C426 have been removed. Make sure that there are no shorts at the C425 and C426 solder pads.
Also R506 has been removed.
Measure resistance between J401 and J402. Measure both ways (i.e. leads reversed).
If you get a low resistance (under 10Ω) proceed with the following.
You are correct, sorry for the most confusing picture.Your picture shows the BLACK probe on the RIGHT leg. Is that correct?
You measured 512Ω on the LEFT leg.
Sorry not beeing specific enough, yes with 0 i mean open circuit, i rather might type open circuit than 0, i agreeIn your report, some measurements are shown as "0" while some are shown as "short".
Can you clarify the difference?
By "0" do you mean "open"?
What reading shows on the meter when you report "short"?
I will do soon!In any case, remove Q430 and test out-of-circuit.
With Q430 removed, repeat the resistance measurements between J401 and J219.
Did you manage to find some more 6.8Ω ¼W resisitors?
Ok. In the meantime, after removing Q430, test Q430. Then test resistance between J401 and J219 (as previously posted in #211).I will do soon!
No,i did not get more 6.8Ω ¼W resistors, the local guy has not been at work, and now it's holidays until next Tuesday...![]()
Yes, Q406 and Q408 are labeled and put aside.Measure resistance across:
(I assume Q406 and Q408 have been removed?)
Removed IC402 from socket.Remove IC402 (in your 8-pin socket) and measure resistance from J401 to J219.
| A | Technics SU VX-800 with blown components (another one) | Technical Repair | 139 | |
| T | Technics SU-V450 not powering up properly | Technical Repair | 1 | |
| K | Request for help in repairing Technics SU-V90D | Technical Repair | 126 | |
| R | Technics SL-PJ1 CD player | Technical Repair | 53 |
