Thanks for the tip. As far as I can tell, Q406, D412, and Q416 all shorting would cause R414 to blow. I cannot tell what was the cause and what was the after-effect.MrChips,
May I recommend the measurement of the Q416 emitter to ground as well as Q414. The shorting C-E of Q416 is the primary cause of R414 dissipating more than 0.25 W. A Q414 C-E short will test R416's ability to dissipate more than 0.25W. If the readings are similar, I would eliminate the loading as a cause of the C-E short.
| A | Technics SU VX-800 with blown components (another one) | Technical Repair | 107 | |
| T | Technics SU-V450 not powering up properly | Technical Repair | 1 | |
| K | Request for help in repairing Technics SU-V90D | Technical Repair | 126 | |
| R | Technics SL-PJ1 CD player | Technical Repair | 53 |
