- Joined Jan 23, 2018
- 28,179
At all times and under all conditions, all delays add. In addition, faster switching reduces the resistance heating as the device switches on and off.
You asked me a question?You didn’t answer my question.
Not sure about wizard (I'm not deaf, dumb or blind yet) but I could usually play for free as long as I wanted to in a typical pinball arcade.If you were a pinball wizard,...
Certainly. The drain pitch is another sure-fire way to assess an arcade in a glance. You have to play a little to learn about the tilt sensitivity.To illustrate, tilt threshold and bumper angles are other attributes that contribute to successful play of at able. A wizard knows by muscle memory or feel, what that parameter is on a given table.
Can't argue with that.At all times and under all conditions, all delays add.
Not likely a problem for a MOSFET used to drive a pin-ball solenoid, even for a several microsecond switching speed.faster switching reduces the resistance heating as the device switches on and off.
My advice for the MOSFET is to go large. By that I mean, if you think you need 10A, spend a fraction more and get 20A. And/or spend to get a lower Rds-on.
The diode D3 is redundant - the other coils are already clamped with diodes?
Really, given that the purpose of the diodes is to protect the mosfet, it is D1 and D2 that are redundant.
OK, if those diodes are already part of the coil assembly then it is D3 that is redundant.
Also, the value of R1 will determine (possibly) the discharge rate of the MOSFET gate charge, depending on how the micro +5V pin operates. So, keep the value a bit on the smaller side, like in the 1k ohms range.
If using discrete through the hole MOSFETs, look into ones like the IRL540 which are common and relatively cheap. They are rated 100V and 28A at 25C with a very small RDSon of 0.077 ohms. With 4V on the gate, RDSon rises a bit to 0.11 ohms, but still very low for triggering relay coils
I have IRF540 on hand but I think I'll go with IRLZ44ZPBF for my next go-to MOSFET. Rated 55V, 51A and Rds of 0.023Ω. Just 99¢.
If a faster turn-off is really needed than a small resistor in series with the diode (say equal to the solenoid resistance) will significantly reduce the turn-off time
The trade-off is that it will increase the turn-off voltage across the MOSFET to twice the supply voltage.
1. No need for flyback diode D3 to protect the MOSFET due to the presence of diode D1 and D2 on the coil assemblyBe careful with a 55V MOSFET when you are running/switching a 48V supply. Any spike on the voltage supply itself could damage the MOSFET.
IRF540 is not good for 5V gate voltages, it should be the IRL540 (or equivalent substitute) when using a 5V device to a MOSFET gate
Sorry, I don't understand your comment... In all documentation I found it is mentioned that you need a common ground when using a MOSFET in order to be able to measure the voltages for both circuits. How do you suggest the design should look like inregards to the GND? Now I have the following:Since the mosfet is switching the current in the 48 volt circuit, use the 38 volt ground for the main connection, BUT ALSO be sure that the gate control loop ground is low resistance.. So really,you do need both grounds, one for the flipper power loop and one for the MOSFET gate control loop.
If the MOSFET is driven from a push-pull output, such as the Arduino, then 10kΩ should be fine.2. Pulldown resistor 1kΩ instead of the generally advised 10kΩ ?
Look for a "logic-level" type MOSFET.5. MOSFET that is usable for 5V gate voltages, but how do I figure that out ?
I partly do understand what you are saying, but I don't know how to draw that in a schematic.Certainly it is true that the grounds must be common. It is also true that swiching a 3 ohm magnet coil across 48 volts will result in 16 amps flowing for a very short time.And 16 amps flowing through even half an ohm of connection wire resistance will develop 8 volts between the two ground points. THAT is why I suggested separate grounding loops, made common only at the mosfet source terminal. None of the coil current should pass through any of the wires connecting the processor board ground to the flipper current ground.
Keep in mind: Ground loops can KILL attached circuits.
Please bear with me, I'm a SOFTWARE engineerThe line from the 48 volt negative supply to the arduino common would be removed, and instead it would go to the mosfet source terminal, or just below the terminal. So the resistor and the mosfet do not need to be so vary far from the arduino, and the entire section with the flipper and diodes could be flipped to the opposite side of D3, then the 48 volt source could be flipped to the righthand side of that vertical line thru D3.
AND, what kind of engineer are you? Your profile says "other".
Here's a pretty nice MOSFET that should be adequate. 100V, logic level, 63A $1.55So given the fact that the coil has resistance I1 = 3.7 Ω (powerful "kick") and I2 = 133 Ω (weak "hold") and the plunger is spring loaded. That I have an Arduino to power 5V and a DC power supply to 48V with a power filter/capacitor board, what do I need given the comment below?
Would it still be better to connect to the power supply GND (going to the wall socket) instead of the Arduino GND?The circuit in post #51 is much closer. But I would still split the two connections to the source terminal of the mosfet. Other than that, it does reflect much closer to how it should be wired. If the mosfet symbol included a circle to define it as a component then the two lined could come to that dot at the bottom (source) from different directions and the tech assembling the circuit could know just what to do. And this is not even mentioned in the EE classes, it needs to be deduced. The whole concept of "ground" is really novel, and mostly incorrect. "True Ground" is a mythical entity, often mentioned but very seldom seen.
OMG DUH! I have this connected this way, obviously, but did not realize this when considering it as a possible GND.The power supply "ground" terminal must be connected to the green wire in the line cord, so that the power supply frame is safely grounded. It has no use in the internal wiring and so it should not connect to any part of the circuit. The power supply negative terminals can be connected to the arduino ground connection.
In this system really there is not a ground, but rather a common, which is the power supply negative terminals.
The meanings of words are really quite important and far to often overlooked. That is certainly a source of misunderstanding and results in a lot of confusion. That is why Itry to avoid using the term ground except for the "green wire" portion of electrical distribution systems, where it usually means an actual connection to the earth.OMG DUH! I have this connected this way, obviously, but did not realize this when considering it as a possible GND.
That high lights the terminology I was trained and grew up in, 'Ground' was very rarely used, it was 'Chassis" "Common" etc, for safety, you used "Earth" or maybe the qualifying, "Earth Ground".The meanings of words are really quite important and far to often overlooked. That is certainly a source of misunderstanding and results in a lot of confusion. That is why Itry to avoid using the term ground except for the "green wire" portion of electrical distribution systems, where it usually means an actual connection to the earth.
