Also, the value of R1 will determine (possibly) the discharge rate of the MOSFET gate charge, depending on how the micro +5V pin operates. So, keep the value a bit on the smaller side, like in the 1k ohms range.
If using discrete through the hole MOSFETs, look into ones like the IRL540 which are common and relatively cheap. They are rated 100V and 28A at 25C with a very small RDSon of 0.077 ohms. With 4V on the gate, RDSon rises a bit to 0.11 ohms, but still very low for triggering relay coils
