I have designed a TL494 half bridge power supply which simulates fine in LTspice but has some problems when soldered on a board and I can not figure out how to fix them.
Schematic pictures are attached.
1. If I connect GDT1 and GDT2 as seen in the schematic pictures, the output waveforms from the push-pull transistors have large voltage spikes. Pictures of the waveforms:
2. If I power the controller part without GDT at around 8V, the circuit draws around 15mA, waveform looks normal. As soon as I raise the voltage to something like 10V, the circuit starts drawing 400mA and waveform voltage from Q1 Q2 push-pull is slightly lower than Q2 Q3. Not only that, but Q1 starts heating up much more compared to Q3. I have tried replacing Q1 and the controller - did not help.
3. After powering up the half bridge with a DC supply (not 320V for testing) the observed voltage shape at MOSFET gates does not look good and they heat up quite a bit. I think this is related to the spikes at the push-pull transistors. Picture of the waveforms:
If needed, I can also take pictures of the soldered circuit.
Thank you for your help.
