MisterBill2
- Joined Jan 23, 2018
- 27,968
My experience ranges from small modules to fair sized machines. And the others who may become involved with a project may not grasp technical jargon. So a "non-biased" segment is less likely to confuse them.
Surely as this point in your long career you are aware that domain-specific nomenclature exists in various industries that is neither "technically" accurate nor self-evident to an outsider—no matter their knowledge of underlying principles.My experience ranges from small modules to fair sized machines. And the others who may become involved with a project may not grasp technical jargon. So a "non-biased" segment is less likely to confuse them.
Yes, and if you are speaking to technicians who zero to little general or theoretical knowledge in an industry that, say, called a diode a "one way resistor" for historical reasons, "diode" has no accuracy at all. You might as well call it a puppy. On the other hand, one-way resistor is perfectly accurate."Y" makes a valid point in post #63.
I did explain the basis of .my attitude in another post this morning. Accuracy in descriptions can be worth thousands of dollars at times.
