Well the + input is weird and all other bets are off. Do power rails look good in this mode.
Did voltage fallower work ( just connect output to v- input) will quickly find a wiring problem.
Still may be oscillating ( does not explain v+ values ) you measure with a scope or Voltage Metter, may be faster than you can read.
Just drop a 1n cap across v- and Out. see what happens. Will not be proper value and its overkill if you are oscillating.
eetech00 pointed out change r109 to more like 1.2 ohms. My simulation can never drive this hard enough to get with 9ohms load.
