Sound amplifier and speaker compatibility with other electronic components (Motor and LED's)
Jacob1994
Joined May 11, 2021
152
Unless he has chosen a different module, the TS will require four of these wired in parallel. The amplifier drives an impedance of 4Ω.
Hey, do you think the speakers should have 3W as RMS or do you think peak? Annie found some that had an RMS of 3W and a peak of 5W but if the 3W was recommended as peak then I can go with those. Not sure what power is best for the 5v amplifier output?
Jacob1994
Joined May 11, 2021
152
Hmm I see, how much in your opinion would the rpm be exceeded by? I don’t really want it going too much over 6rpm, would it be safer to get a 4 or 5rpm motor for example and then if the rpm was slightly over it would be closer to the 6?
Sorry I misread your answer; the motor I’m using is a 12v
35,314
I just conducted a quick test.
I have a Simpson Model 886 Sound Level Meter.
With 100mW rms music into a 3" loudspeaker, the meter placed 1 foot from the speaker reads in excess of 80dB.
And that is LOUD!
BobTPH
Joined Jun 5, 2013
11,678
The power rating of a speaker says nothing about how loud it will be. The relevant specification is “sensitivity” stated in dB at 1W input at 1m. 90 dB is very efficient. Small speakers will not be that high, except , perhaps above 1KHz.
But then, none of these no-name speakers have hat spec listed.
Bob
Jacob1994
Joined May 11, 2021
152
Hey guys,
So the majority of my components arrived today, just tested out the motor which seems to be working well, a bit louder than I anticipated but I'm sure most of the noise will be confined by the casing around and above.
Turns out the button I ordered for the power on/off is a hold-down push button so no good for the main power as it has to be held down, although I'm going to order 3 more of this type and use them to control the volume/play/repeat function of the soundboard as these should just require a quick push and release.
https://www.digikey.com/en/products...235501?s=N4IgTCBcDaIMoHUBsYCcBaAcgEQAQgF0BfIA
I was wondering if you guys know if there is a push button that is a click release button similar size and shape to the one mentioned above, ideally on the same website so I can order it along with the 3 additional push buttons? I'm trying to search but can't seem to find any mention to a click button on the search options in the link below:
https://www.digikey.com/en/products/category/switches/15
Anyone's help is always appreciated!
Thanks,
Jacob
Audioguru again
Joined Oct 21, 2019
6,826
The tiny speakers made by a no-name-brand company have no detailed audio spec's. The Name-Brand speakers from Digikey and Madisound have the same price as the poor quality no-name-brand speakers from Amazon.
The speakers from Digikey and Madisound have specs that say they will not be loud and will produce no low frequencies (like all tiny speakers) but their high frequency response is good as tweeters. They will produce squeaking sounds.
The amplifier also has no detailed audio spec's but similar amplifiers like the PAM8403 that produce 3W of very distorted noise or 2.5W of low distortion audio into 4 ohms when its supply is 5V.
A clock radio produces about 0.5W but its speaker is much larger and much louder than the tiny speakers (shriekers) used here.
A clock radio speaker produces some low frequencies unlike the tiny speakers.
Therefore a clock radio will be much louder than the system planned here.
Jacob1994
Joined May 11, 2021
152
Ya’akov
Joined Jan 27, 2019
10,370
Hey guys,
https://www.digikey.ca/en/products/detail/apem-inc/401ZQE/1280084 - 1A 125V
https://www.digikey.ca/en/products/detail/e-switch/PS1040BBLK/1802903 - 3A 125V
So I ordered these two switches last night, I'd like to use the top switch since the mounting is attached to the front, however the current rating on this is only 1A. Will this not be able to handle the current going through my circuit? The lower one should certainly be able to handle it, which I got as a backup.
Thanks,
Jacob
You can figure this out.
What is the switch connected to? What are the voltages and currents for that connection? Unless the switch is connecting the battery to the device, the voltage will be a logic level one (5V or 3.3V likely) and the current will be vanishingly small.
Jacob1994
Joined May 11, 2021
152
your probably right Yaakov, I just have very little confidence in this area lol.
Well I think the switch is going to be connected to the main power after the female power jack. The switch will keep the circuit on/off for the 12V motor, as well as wires going up to the slip rings for the above LED’a and the 12v - 5v converter which will provide the power for the sound board and speakers. So this essentially will dictate the flow of power to the whole system.
Ya’akov
Joined Jan 27, 2019
10,370
OK, then add up the current requirements for each part, simple addition. The switch is not rated at 1A DC, that rating is AC. The DC rating, according to the datasheet is .5A at 28V.
Jacob1994
Joined May 11, 2021
152
Ah ok, well the LED's are 1A, then the motor is also 1A. The sound board current rating isn't specified but it will be at a lower voltage of 5V. The speakers also don't show a current rating but their impedance is 4ohms and their rated power is 2W
BobTPH
Joined Jun 5, 2013
11,678
You are using a 12V 1A motor for this? That is severe overkill. I made a prop for a dance routine that was a like a music box with spinning ballerina, except, to be really visible, the ballerina was a Barbie dell (i.e. 9" tall). She had lights on her dress, so similar to your project in that I had to get power to the lights on a spinning platform.
My solution had the motor and battery inside the spinning part, thus no need for slip rings. The motor was 3.7V at 30mA, which is less than 1% of the of the power of the motor you are using, and it had more power than needed.
Edit: Changed avatar to be a picture from the routine. My wife's dress is identical to the one on the spinning doll, and it lights up too!
Bob
Jacob1994
Joined May 11, 2021
152
Hey Guys,
So I tested out some of the components today, the motor works fine, but for some reason, the LED's and the audio amplifier/speakers aren't responding when I connect them to power.
My main concerns are the following:
  1. I do not know which contacts are positive/negative for the power jack as it is not indicated?
  2. At one or two points the positive and negative wire connected to the same contact and a small spark occurred, may I have blown some of the components?
  3. How can I determine if it is an issue with the power or components since the motor continues to work with the current wall adapter and power jack it should be an issue with the components or my wiring?
Below are the following components I'm using:
Power jack:
https://www.digikey.ca/en/products/...10?s=N4IgTCBcDaIAQGUDCBGADAFgJwFoByAIiALoC+QA
Wall adapter:
https://www.amazon.com/gp/product/B086SQLRBP/ref=ppx_yo_dt_b_asin_image_o01_s00?ie=UTF8&psc=1
LED's:
https://www.ebay.com/itm/2733042044...var=572654974121&_trksid=p2060353.m2749.l2648
Speakers:
https://www.digikey.ca/en/products/...s=N4IgTCBcDa4IwAYAsBaAygWQMyLMlcKAcgCIgC6AvkA
Audio amplifier:
https://www.amazon.com/gp/product/B07YYYRGZC/ref=ppx_yo_dt_b_asin_image_o00_s00?ie=UTF8&psc=1
Volt converter:
https://www.amazon.com/gp/product/B07P663XJV/ref=ppx_yo_dt_b_asin_image_o02_s00?ie=UTF8&psc=1
Motor: Works
https://www.amazon.com/gp/product/B074K1Y775/ref=ppx_yo_dt_b_asin_image_o01_s00?ie=UTF8&psc=1
The image attached shows the wiring method for the speakers I'm using.
Audioguru again
Joined Oct 21, 2019
6,826
Everything except the jack has the correct polarity shown. The polarity of the jack is simply measured. Don't you have a multimeter?
You probably got the polarity backwards and blew up things.
Jacob1994
Joined May 11, 2021
152
Everything except the jack has the cirrect polarity shown. The polatity of the jack is simply measured. Don't you have a multimeter?
No I don't have a multimeter, I'm not a frequent user so have never owned one. I hope that isn't the case.
I tried just one speaker instead of the circuit, it seems to make a few crackly noises for a minute when I connect the power and the USB flashes but no song appears to play. Not sure if I can only have mp3 files on the USB since I currently have some other documents on the USB I was testing
