Sound amplifier and speaker compatibility with other electronic components (Motor and LED's)
Jacob1994
Joined May 11, 2021
152
Hello Everyone,
So all components are now good, I've sent the first piece of the project to be 3D printed as a test for quality.
In preparation for when all of the prints are ready to assemble, I'm trying to create the logic for the wiring in the model so I can go through it step by step checking wiring off as I go along.
I've by no means finished modelling the basic wiring that is straightforward and doesn't require much thought, I should have that done in the next day or so.
The wiring setup I want to make sure I get right is as follows:
- Master power button to power all 3 systems
- Ability to turn on/off the 3 systems (lights, motor and audio) separately if needed. i.e. keep motor and lights with no music, etc
I hope the attached image with the control buttons helps to explain what I'm hoping to achieve. I'm pretty confident there shouldn't be any trouble setting up the audio control wiring since they are simple single circuits.
I'm trying to make sure when I have the wiring setup for the motor, lighting & audio that I get this correct as it gets a little bit messy with all the wiring crammed into the box. I want to make sure I have the option to turn all of the 3 off by pressing the single power button but am also hoping it will be possible to incorporate a power button for each of the 3 (motor, lights and audio) so in the instance that one or 2 of the systems wanted to be shut off this option would be possible.
I hope I explained what I'm trying to do in a clear manner. Please let me know if not and I'll try to explain it differently.
I appreciate everyone's help as always.
Jacob
Jacob1994
Joined May 11, 2021
152
Your master power switch is feeding 3 sub power, 1 for each devices. 5 minutes job at most.
And if I wanted to close the power for one of these sub power how would I set this up without breaking the circuit?
If I’m understanding correctly I need to create a circuit that connects from the power jack to all 3 components whilst at some point in the circuit connecting to the master power switch.
For powering individual systems I need to wire to only one system, the motor for example, and connect this to the appropriate switch?
Jacob1994
Joined May 11, 2021
152
No, jack>master>3x devices switches. Or, jack>master>device switch>device. Repeat master>device switch>device. Sorry for the confusion.
Ah that actually makes sense to me! Thank you :)
And am I right to assume I'll have to connect the wiring from the 3 separate switches to the pins on the master switch or can I connect it along the wire that links to the master? I'm thinking I'll need to connect to the pins on the master switch.
35,280
Ok, either way I go though I'll be wiring my devices twice correct?
What do you mean by wiring it twice?
To me that means wiring it, removing the wires and wiring it again.
With one ON/OFF switch you can control the power to the entire project.
If you want to control three sections of the project independently then you will need three switches.
If you want to control the entire project with one switch AND be able to turn off individual sections then you will need four switches.
BobTPH
Joined Jun 5, 2013
11,666
I don't understand that question The devices get one ground wire and one wire from the device switch.
Someone who’s is not on a ohone, please draw a schematic.
Bob
Jacob1994
Joined May 11, 2021
152
I mean I'd need to wire all 3 of my devices to the master switch and then wire each of the devices to the separate switches as well? I have my switch setup to the last configuration you described.
35,280
Think of how your house is wired.
There is a master switch in your service panel.
Then there is a separate wall switch to the room light in each room.
There are two wires going to every light bulb. The switch breaks the circuit on one side only, the LINE wire.
S5 in the circuit below is not necessary.
This will do:
Jacob1994
Joined May 11, 2021
152
This will do:
That's a great description and circuit diagram, thank you so much! :) :) :)
I'll follow this when all of the prints are made and I'm ready to start wiring.
Thank you also Annie for your help, and you too Bob :)
Jacob1994
Joined May 11, 2021
152
Hey guys,
Good news, I've ordered all of the 3d Prints so just have to wait for them to arrive now. Won't be able to start wiring until July 10th when I'm back from vacation. There was one last thing I was hoping to try, which is to have a click in connection for the wires between where the base and top of the model connect so when I remove the top and bottom of the model I don't pull the wires connected to the LED lights above. Is there any type of component anyone could suggest?
