PERFECT.You can see here that the motor will stop if the FWD and REV inputs are both activated.
No additional circuitry is required.
Built boards. Due to eyesight had to make and toss 9 to get 1, each taking 4-6 hours.PERFECT.
Charged motor cycle batteryWhat are you using for the 12 volt supply?
I made a 6 hole x 28 hole bum proto pcb and it was the perfect size as a gum stick to go across a phone screen...the operational position for this with phototrans on each end towards edges. Etching will likely get 2-5 more horizontal tracks so I can collect them on one edge for a cable etc.That's not going to work.
You can't change the circuit to fit the pc board design.
R3 and R6 must return to the +12 volt trace somehow.
Are you trying to use all surface mount components?
The first gerber file attempt was to figure traces for std components I have. Eventually I suppose I will need surface mount components so I am practicing.I made a 6 hole x 28 hole bum proto pcb and it was the perfect size as a gum stick to go across a phone screen...the operational position for this with phototrans on each end towards edges. Etching will likely get 2-5 more horizontal tracks so I can collect them on one edge for a cable etc.
Rewired.to original 47k. Different attempts failed.
And now this.Don't forget pin3 is also connected to pin5.
Quote for 45.boards: $5 eachYou are too quick! Ping! Like a science teacher with a stack of quizView attachment 344808zes..and a BB gun...
11 parts plus fem USB header, 30 holes and joints, 30-60 minutes with etching and assembly. Any bets on a proshop price?
Does that include all the components and assembled?Quote for 45.boards: $5 each
I have to buy/add components...less than $1 each.I
