yeah , i understood, because quick glance at image saves a lot of timeThanks for the reply, Sophie! I agree that a drawing is often easier to understand than text, and my very first post has a PDF file attached to it with a sketch of what I originally had in mind. I first did that document as a PNG file, but redid it after reading in the forum guidelines that PDF was the preferred format.
In response to my original post, I received some excellent suggestions that would help me with that approach, suggestions about using sound or vibration to detect when the plastic ball strikes the target, and a suggestion from Bernard to look into using a sheet of Velostat between two pieces of aluminum foil as the target.
As Bernard made suggestions and I worked on figuring out how to implement them, I attached PDF drawings to several of my posts to confirm I understood what Bernard had in mind. I believe the vast majority of the text in this thread consists of questions, comments, and suggestions about the information on those drawings.
If I'm wrong about attaching PDF files being the preferred method of sharing drawings in this forum, I'll be happy to switch to a different file format for any future drawings I upload.
Thanks again for your reply.
I forget what I calculated as the number of times a plastic ball might strike the target area in the course of a year, but off the top of my head I'm thinking it will be less than 300,000.Will aluminum foil be robust enough? What about stainless shim shock. It's expensive though.
I ordered a 4' x 3' sheet of Velostat, and am going to use less than 2 square feet of that for the target. Instead of cutting stacks of paper to make a spacer that goes around the edges of the Velostat, is there any reason I couldn't make the spacer out of Velostat and one sheet of paper?Spacer same or better if .002 thicker than Velostat.
Thanks again for your help!Example of sensor life might be that FSR 400 series pressure sensors are tested to 10M cycles & these are around 1" dia. Velostat + other supporting materials. So- there is hope. Might have to patch outer film @ some point? My fingers are crossed.
Thanks again for your help!What scale is meter on? The AL foil sheets & Velostat need to be as flat & wrinkle free as possible to keep the sensor resistance as high as possible, around 1k.
Try to aim for 3:1 or better. If necessary the target can be subdivided to keep R high then ORd to give one signal. Recheck post # 23 & # 31.
Just to be clear - the numbers I put into post #72 were not actual readings. I the numbers out of the air as easy to multiply values that would help see if I understood what you meant by a 3:1 ratio.Information from post # 72 much more helpful than meter readings.
600 ohms vs. 50 =12:1 = great. Drain @ 600 ohms about 8 mA or 250 hours on AA alk. batteries. That is why we want to keep resistance high as
possible. If resistance is as low as 300 ohms we might want to use a comparator for hit detector. My test sensor, 10" X 12" gave 5k so 8" X 18"
could possibly be as high as 6k ohms?
Bernard, I created and teach a 2-Day "Basic Hydraulics" course. I visit a company's site, and by the end of the course, mechanics who had been trying to fix hydraulic problems through trial and error are able to dramatically reduce their company's hydraulic-related downtime because they understand what all their hydraulic components and systems do, can read hydraulic schematics, and know what it takes to get the longest, most productive life from hydraulic components and systems.If post # 72, last paragraph, is not a real measurement then we have no proof that your "Velostat" is a pressure sensitive film. Could you humor an old ( 93 )man & measure the resistance between two AL sheets which are separated by a sheet of " Velostat",lying on a flat surface, first with no added pressure & second
with thumb pressure ?
Bernard, thanks again for all your help!The bottom layer , target, can be any thickness of AL foil.
