Dehumidifier humidity sensor (2)
BarrieB
Joined Nov 16, 2026
Does anyone know if the sensor in the Electriq dessicant dehumidifier DESD9LW is the same? Mine reads ~90% most of the time, when the actual value varies between 40%- 50% and is set to 60% so it stays on consuming power but not achieving anything.
It seems to me that the sensor needs replacing, but I can't get to the dehumidifer easily, so would like to get the part beforehand if possible...
Moderator edit: New thread created from this.
B-JoJo-S
Joined Jan 3, 2026
602
It's always wise to fully diagnose the problem before you start throwing parts at it. You may end up with a brand new dehumidifier for your power cord. Also, welcome to AAC. Also - you are encouraged to start a new thread as opposed to taking over someone else's thread. Unfortunately I don't have an answer for you.
C General Electronics Chat 19
