Completed Project ELEGOO Centauri Carbon 3D Printer tangled filament. sensor
Wendy
Joined Mar 24, 2008
23,821
Tangle Sensor PIcture.jpg​
As much as I love my new printer, changing the filament is pretty easy. Unfortunately, every time I change the filament I have problems with tangles in the spool. So I built an alarm circuit when the tangle causes the pulley to be pulled off the base with that is attached with magnets It sounds an alarm so I can pause the printer and untangle the filament. Unfortunately, it may do it more than once, so I just have to live with it. The ELEGOO Centauri Carbon 3D Printer printer allows me to pause the print long enough for me to go fix the problem and complete the print. Until I got this online, I lost more than one print in the process. I used 4/40 x ¼“ screws to attach the various pieces of the table mount together. The holes in the print are the tap size for the screws. The soft plastic is easily inserted with these screws. Most of the magnets I used are variations on 5/8” or 5/16” diameter magnets. I used window sensors similar to these I can no longer get those parts so the holes may not be the right place. I've had them for over five years, go figure. The magnet side of the sensor is mounted in the pulley along with two magnets to firmly attach it to the table mount, Which has the contacts used by the alarm circuit. When the pulley is dragged off the table mount, it opens the circuit and the alarm goes off.
Magnetic Door Sensor.png​
There is a minor Design flaw w/ pulley base with magnets STL in that the retaining screws for the magnetic door sensor overlaps with a magnet. I cheated and used a drop of super glue to retain the top to the pulley base. The pulley comes in two parts The top half slides over the bottom half, I used super glue to hold them together. A #6/32 screw that had been cut down to full use as the pulley shaft. I used a #6/32 countersunk screw with a #6/32 wing nut as shown, to attach the table mount to the table underneath. I used superglue to attach the wingnut to a #6/32 countersunk screw.and cut it down as needed. I keep a stock of screws two inches long. I cut them down when I need to.
Wing head#6_32 Screw.jpg​
I built the circuit on a small protoboard and mounted it on the base of the box using two small retainers I made to hold the protoboard in the box stationary.
And here is the schematic and layout:
Alarm.png​
I used an existing voltage, 17 to 24VDC, that I used for my filament warmer to power the total circuit. I used a 15V regulator to get it down to where a CMOS 555 can handle it. Why CMOS? This kept the regulator running cool at 15V a CMOS 555 has pretty decent specs.
The sides.STL files have something I call square strain relief. You glue the wires into this square strain relief, and put them in the side that has the gap. This is the sensor leads and the power supply leads. When you slide these wires down the gap in one of the sides You then use the gap filler to plug the gap in side right and plug that hole.
BobTPH
Joined Jun 5, 2013
11,651
I have to where you are getting your filament? In all the printing I have done, i have only seen a snag on one reel.
Wendy
Joined Mar 24, 2008
23,821
If I had two hands, I could probably do a better job of not tangling the filament. as is that which cannot be cured must be endured. I have gone through several spools while completing this project. One spool was tangled so bad I cut the filament, let the printer run out of filament and rethreaded it with the cut end. It worked fine after that.
Jon Chandler
Joined Jun 12, 2008
1,645
I recently got a Creality Sparkx i7, and I must say, I'm impressed – it's a whole different game than my used Ender 3 clone. For the most part, to steal T-Mobile's slogan, it just works.
In over 10kg of printing, I've had one problem where filament broke and it took some effort to find a tiny bit in the extruder that was blocking a sensor and another problem apparently caused by a gunked-up hot end. I'm confident that prints that take hours will be great.
Here are a couple pictures to tease you. The sushi boat is a file my partner found online. We added holes for the skewers.
The sauce dinghies were my own creation. Can't just leave the sauces bobbing around free you know!
The wood grain texture was applied using a site called BumpMesh. Upload an stl, and you can apply a variety of different textures.
20260821_182440.jpgScreenshot_20260905_021130_Gallery.jpg20260821_050855.jpg20260821_182440.jpgScreenshot_20260905_021130_Gallery.jpg20260821_050855.jpg
