Schottky Diode as overvoltage protection
Jos_EE
Joined Nov 9, 2019
At work, they are using this structure to protect an analog pin on a micro-controller from overvoltage.
I simulated the circuit and wired it up to test it (physically), but the output is linear in both (which I expected). One engineer at work assures me this works, and that once V5 = V6 + 0.6V, increasing V5 will not increase the output.
If it does work as overvoltage protection, can anyone explain or point to a resource that can help understand it?
wayneh
Joined Sep 9, 2010
18,184
I don’t get it. Why doesn’t D5 blow up from overcurrent? Why is V6 relevant at all? It won’t matter unless/until the 30V breakdown is passed.
Papabravo
Joined Feb 24, 2006
22,116
It may work for over voltage protection but this method would not be my first choice. Are you aware to capacitance of each of the diodes? they will interact eith the source impedance of the signal source to make a low pass filter. D5 will limit voltage excursions below GND to whatever the forward drop of the diode is, which is a function of current. D6 will limit excursions above one diode drop. Your friend gave you the figure of 0.6V which might apply to a silicon diode, but I would expect a Schottky to be better than that
FWIW, I would use a cheap opamp follower and a series resistor to limit the current into the opamp input. The opamp will also help to overcome the capacitance of the diodes.
In your simulation - do an AC analysis to see what happens to fast signals on their way to the A/D converter.
Jos_EE
Joined Nov 9, 2019
Thanks wayneh
As explained to me, V6 = 5V. When V5, which is a user input, increases to about 5.6V, the diode D6 will start conducting. According to this person at work, once the diode starts conducting, even if V6 is increased, the voltage will remain the same.
D6 doesn't blow up because there is no load or resistor pulling a large current.
dendad
Joined Feb 20, 2016
4,642
I use the dual diode clamps quite well, but there is always a series resistor from the input signal to limit the current.
The signals I measure are not fast so the diode capacitance is not a problem. In fact, there is always a cap to 0V for noise filtering anyway.
"V6" sets the +ve max volts to the micro input to V6+D6fwdV.
Likewise, the max -ve volts is 0V + D5fwdV.
This setup works quite well in the real word.
wayneh
Joined Sep 9, 2010
18,184
Thanks wayneh
Yes, I can buy that it works. If the voltage gets too high, the current in D6 will roast it.
Jos_EE
Joined Nov 9, 2019
@Papabravo thanks
The circuit doesn't really run at AC, it is only meant to read a voltage from 0 -> 5V, so I'm not too concerned about the frequency response, but I do agree there would be a low frequency filter.
Papabravo
Joined Feb 24, 2006
22,116
@Papabravo thanks
The problem with that thinking is that if it can be any value from 0 to 5 then it is NOT DC. If it is allowed to change even at a sub 1 Hz. rate then it becomes AC. for an extreme example have a look at this article about an organ piece that takes over 600 years to play. THAT my dear fellow is really at the low end of the frequency spectrum.
https://en.wikipedia.org/wiki/As_Slow_as_Possible
Jos_EE
Joined Nov 9, 2019
@dendad Thanks for including the name "dual diode clamp." I was able to look up and I'm now able to find other resources that are helping paint a better picture.
