Schottky diode with low leakage current
STech2106
Joined Jul 8, 2023
43
Hi guys, I have a question about the B220A-13 diode. Here is the datasheet:
B220A-13
I need it to absorb negative spikes, but since it is used in a battery-powered system, I am afraid that the reverse leakage current is too high, even though it is rated for VR voltage. Are there any diodes with the same characteristics but with a very low leakage current for use with batteries?
PS: It is placed at the output of an eFuse at a 5V output voltage.
WBahn
Joined Mar 31, 2012
33,198
If someone is going to go to the trouble of trying to help you find a diode with a sufficiently low leakage current, doesn't it make sense for you to tell them how low the leakage current needs to be in order to be sufficiently low?
38,820
The 30V version of that diode has ≈3µA leakage @5V (below) at room ambient.
Edit: The leakage typically doubles for every 10°C increase in temperature.
schmitt trigger
Joined Jul 12, 2010
2,234
Depends a lot on the impedance of the node where it is connected.
Several moons ago I required the protect a analog buffer input. A pair of Schottky diodes, correct? Not so fast, the source impedance was 1 Meg, and as shown in the plot provided by Cruts, even at ambient temperature, the leakage created a voltage offset which swamped the signal to be monitored.
As a rule of thumb, utilize a diode with a reverse withstanding voltage at least twice, better thrice, the maximum expected voltage. Additionally choose a diode with the smallest current carrying capability consistent with adequate margins, and if possible keep the diode the farthest away from heat sources.
But one thing is certain, a Schottky will never have a leakage current as low as a plain vainilla silicon junction diode
