schottky diode ?
MrSoftware
Joined Oct 29, 2013
2,273
Relative to standard diodes, schottky diodes typically have lower forward voltage and faster recovery times (better for higher frequency switching), but a little higher reverse leakage current. Looking at the use case for your circuit, could these behaviors benefit you?
joewales44
Joined Oct 8, 2017
218
yes, switching regulator is PAM2861 or AL8861.
i thought ss24 would be a good choice?
lower voltage drop is the main reason i chose these.
i don't know what problems higher reverse current leakage would cause.
