Schottky diode between base to emitter terminal
Sensacell
Joined Jun 19, 2012
3,789
It clamps the node there to negative ~0.4 volts on the negative edge of the input waveform.
This is called "DC restoration" the signal on the cathode then goes from ground to the highest input voltage- remaining positive.
It also prevents possible reverse breakdown of the BE junction if in input voltage is over 14V P-P.
