So, I ordered same Inverter board on AliExpress, because I read somewhere that it can be the issue.. when I placed the AliExpress board, it worked for a day, then the same 3C2 error happened. 3C2 error only shows in test mode, in normal program mode it only restarts selected cycle.I'm just wondering, why the eBay board you tried, didn't work?
I found for a very similar washing machine, but it wasn't very helpful... Because the solution is like replace the board or other part... Let me attach it in a minuteHave you got service manual for that machine!?
Here is the manual,Have you got service manual for that machine!?
I only want see what the 3c2 error in the manualI found for a very similar washing machine, but it wasn't very helpful... Because the solution is like replace the board or other part... Let me attach it in a minute
Are both boards have same error now? When you try to operate on the washing machine?
Please check this chip if there is any short between any two pins all over the chip, on doide mode in multimeter
That's the motor driver chip View attachment 362627on diode mode, are they the same for two boards?
red connected are shorted pinsI have checked the wires with continuity and shapking them... if thats what you are asking, they are fineSay motor driver error
Have you checked the phase wires with motor body?, if there is any connection?
In both boards, or only one board?View attachment 362639red connected are shorted pins
Only original board, I haven't opened new board. There is no hall sensor. Connectors are okay, I tried with different wires too.In both boards, or only one board?
Compare with new board pleaseOnly original board, I haven't opened new board. There is no hall sensor. Connectors are okay, I tried with different wires too.
I can only inspect connectors on new board, since new board is sealed in silicone as the old one was...Compare with new board please
Here manual, say there is hall sensor
There is no hall sensor.Here manual, say there is hall sensor
| Thread starter | Similar threads | Forum | Replies | Date |
Samsung LED TV showing double image | Technical Repair | 3 | |
| L | Is it safe to power an ESP32 WROOM board with a Samsung mobile phone charger? | General Electronics Chat | 7 | |
| P | Samsung ssd evo870 sata 3 fail | General Electronics Chat | 2 |
