I have DC92-02139A inverter board that I took of my washing machine. and I am trying to repair it. Washer shows 3C2 error (Driving part stop(motor overcurrent error)). The motor tries to spin in service mode, but it's only like continuous twitching a little bit.
I tried to change some parts, replaced IPM chip, swapped some resistors, but I am not sure what could be wrong... I have attached the image of the board itself (I have removed IPM for the second motor from the board, and the left upper side is less important because it controls secondary motor, i have two exact boards that are acting the same, one is original(the one im trying to fix, and another i ordered from aliexpress that worked like for one day))
Large capacitors are ok, i tested them with multimeter. It has 2 BLDC motors.
So if anyone have any ideas please let me know.
Thank you!
Thank you!
