R1 is the serious parasitic resistance of the battery? Or does it simulate the load?hi,
You could try this SLA sim.
Unzip the files.
sc = state of charge 0 > 1
nc =number of 2V cells.
E
Unzip the files.
E
Hi Eric, sorry to bother you again.Hi,
It is just demo dummy load for the battery check, to show it working
E
Hi Eric.hi k89,
Please post the LM5109B asy file.
E
I do NOT have the .asy files of the two components, I have:Hi Eric.
I've reorganized the graphs and simulations a little bit and I'd like to show them to you.
I remind you that the circuit is this for EPC2152:
And the circuit is this for LM5109B:
I didn't report it explicitly in the schematics above, but I simulated both the circuits with .step param D 0.05 0.1 0.15 0.20 0.25 0.3 0.35 0.4 in order to obtain an output current range from 6A to 50A
With the .meas on the left I found the following data for EPC2152:
With the .meas on the left I found the following data for LM5109B:
In this first graph I plotted Efficiency vs Iload at difference Frequencies for currents up to 25A (so ducty cycle max 20%):
View attachment 342051 figure 1
In this second graph Efficiency vs Iload only at 60kHz but for currents up to 50A (so ducty cycle max 40%)
View attachment 342058 figure 2
What I don't understand is precisely the trend of figure 2, which does not take into account switching losses (because the frequency is always the same 60kHz) but simply takes into account conduction losses R*Iload^2:
View attachment 342057figure 3
Since conduction losses increase with increasing load current (figure 3) ... shouldn't efficiency (in figure 2) decrease as Iload increases? ..which does not happen (figure 2) .. the opposite happens!
At this point I also ask you for feedback on figure 1
If you think so I can open a new post so that maybe other people will respondI do NOT have the .asy files of the two components, I have:
RAW files
PLT files
LIB files
Perfect.hi k89,
If you consider that there is a change from the original topic, creating a new thread would be the correct action.??
E
