Retuning Pi Filter & Antenna Matching for nRF52 BLE
KALYAN327
Joined Jan 19, 2025
Hi everyone,
I’m facing issues with my nRF52 BLE design due to a solder mask thickness change and grounding approach. I’d appreciate expert guidance on retuning the Pi filter, recalculating impedance, and resolving grounding concerns.
Issues Faced:
  1. Solder Mask Thickness Change:
    • Ref NRF52 DK design: Solder mask thickness = 0.0175 mm.
    • My design: Solder mask thickness = 0.035mm. See image 1.
    • Impact: Impedance mismatch and high resistance readings (~MΩ) at the decoupling capacitor near the antenna and radio ground pin.
  2. Grounding Concern:
    • Recommended Approach: Radio ground pin should connect to the decoupling capacitor via a trace before connecting to the ground plane. See image 2.
    • Current Design: The radio ground pin connects directly to the ground plane using vias, bypassing the decoupling capacitor.
  3. Impedance Mismatch:
    • Pi filter components (C1=0.8 pF, L=3.9 nH, C2=0.5 pF, C3=1.2 pF) were designed for the previous solder mask thickness. See image 3.
    • With the updated solder mask, the effective dielectric constant and parasitic values have changed, resulting in potential impedance mismatch at 2.4 GHz (BLE frequency).
What I Need Help With:
  1. How to recalculate C1,C2,C3,C_1, C_2, C_3,C1,C2,C3, & LLL for 50 Ω matching? Tools/methods?
  2. How to adjust for 0.035 mm solder mask thickness and recalculate microstrip impedance?
Any guidance is appreciated!
  1. Should the radio ground pin route through the decoupling capacitor instead of direct via to the ground plane?
  2. Best way to validate updated design (e.g., S11, VNA settings)?
Additional Details:
  • Design Context:
    • PCB: FR4 material.
    • Frequency: 2.4 GHz (BLE).
    • Antenna: Custom trace antenna.
  • Tools Available:
    • Saturn PCB Toolkit, AppCAD, and access to a VNA for measurements.
  • Objective: Achieve optimal impedance matching and address potential grounding-related performance issues.
I’d really appreciate any advice, calculations, or recommendations on fixing these issues. Thank you in advance for your help!
