Remote control by location (PIC in Oshonsoft)
camerart
Joined Feb 25, 2013
3,847
hi,
Tried a number of ideas, they will not work together in simulation, on receive.
E
Hi E,
I'm trying to follow your image #599.
RA4 should be input, and another should be output, I'm using RB3 as it is free. AN0 to AN4 are analogue inputs.
I've just noticed that I have ALLDIGITAL and Analogue pins set up. I'm trying no analogue pins to see what happens.
When using the SIM it stops at [ Serin PORTA.4, 9600, azi.LB, azi.HB ] I can't remember what to do next. What do I enter into the UART? SEROUT is showing in the UART.
C
ericgibbs
Joined Jan 29, 2010
21,547
hi,
Ref 599.
It was a test of the simulator to check if it is possible use a SW and HW port in the same program.
I chose PORTA4 and PORTA.5 as SW, as PORTC is used as the HW port.
I found when used together the program locks up.
I assume its the way OSH compiler uses the internal hardware of the 18F.
E
camerart
Joined Feb 25, 2013
3,847
hi,
Ref 599.
E
Hi E,
To clarify: "I found when used together the program locks up." Do you mean when SW and HW are used together OSH can't work?
If so, then I will need to re-design the PCB. If you recall, I have a switch on the 18LF4620 RX. The switch is a two way switch, but I bought a four way switch for the above purpose.
C.
ericgibbs
Joined Jan 29, 2010
21,547
hi,
Thats what the simulation shows , they don't work together.
It supports what you are finding in your HW, you could drop Vlad a Debug message, see what he says.
E
camerart
Joined Feb 25, 2013
3,847
hi,
E
Hi E,
I just checked my PCB designs, and back in August, I had almost redesigned the latest PCB with a 4 way switch, and only using HSEROUT, HSERIN, so I'll carry on and finish it, and see if it works as expected.
I'm a bit puzzled, because up to a couple of weeks ago, the SERIN was working ok. I'll drop Vlad a message.
Thanks,
C.
ericgibbs
Joined Jan 29, 2010
21,547
hi,
Did you still have the Hseropen 9600 Code line in the test program.???
IF yes, this would assign PORT.6 & 7 as HW Uart pins,even though you do not use them.
E
camerart
Joined Feb 25, 2013
3,847
I've re-designed the PCB, here:
I've added a multi way DATA SWITCH, Here:
I'm still propogating the PCB, but the 18LF4620 is working. There are a few errors on the PCB.
I got a bit confused by the DATA SWITCH. Am I correct that for 1A-1B1,1B2,1B3 1B4 to work OE1 and OE2 should be LOW?
C.
camerart
Joined Feb 25, 2013
3,847
I've forgotten how to send and receive HSEROUT/IN. I suspect it's a string, where an example is in the program.
Here is the program. Looking under [On High Interrupt 'On Interrupt#####] is a section of serial in, but not HSERIN.
Can someone give me an example os HSEROUT (18F4431) and HSERIN (18LF4620) to test the switch please.
C.
djsfantasi
Joined Apr 11, 2010
9,237
hi C,
This is a test program we did back in 2014.:rolleyes:
It has In and Out and some examples
E
Note: Line 54 has a Break, just rem it out.
C.
Sorry, I can’t give you an example. But HSERIN() doesn’t return a string. It returns a byte representing a single character.
You can construct a string from a series of characters yourself. For each character read, append it to a string until you reach a termination character.
At least that’s what I’ve needed to do I’m another language. The only exception has been where all inputs have been one character and I could ignore/discard everything else.
This is a different way of thinking. If you can get it, great! Otherwise, I hope I haven’t confused the situation.
ericgibbs
Joined Jan 29, 2010
21,547
hi dl,
This is a clip from the above file,
For convenience when using the Sim, we use the '?' as an end of line for testing.
E
read0:
Hserin char
char = Chr(char)
If char <> "$" Then Goto read0
nxtchr:
For x = 0 To 5
Hserin char
If char = "?" Then Goto echoout
inpmsg = inpmsg + Chr(char)
Next x
djsfantasi
Joined Apr 11, 2010
9,237
hi dl,
E
read0:
Hserin char
char = Chr(char)
nxtchr:
For x = 0 To 5
Hserin char
Next x
Yep! I got it, eg.
I was responding to c’s post. Specifically this.
camerart
Joined Feb 25, 2013
3,847
Hi D,
I can follow, E's example, and I'll try it. It looks like both languages use the same method.
Thanks,
C.
camerart
Joined Feb 25, 2013
3,847
First I tried adding the QEI sequence into the MAIN program, where there are many duplicated parts e,g, CHR is used elsware, so I changed the names. It didn't work:(
Here is a shorter version.
Note: ACHR doesn't work as WORD, so I changed it to a STRING? It still doesn't work
The 18F4431 is outputting [ Hserout "QEIDEG= ", #QEIDEG, CrLf ]
C.
