Remote control by location (PIC in Oshonsoft)
camerart
Joined Feb 25, 2013
3,853
hi,
With RespecT
The Crlf has nothing to do with the MidStr command, you are only select 3 chars form the msg.
E
Hi E,
I follow, but I wanted you to check that the sentence being sent from the 18F4431 is acceptable, before going and farther.
I tried the example you gave and it produced this:
I wanted to make sure that I was on the right track.
C.
ericgibbs
Joined Jan 29, 2010
21,606
hi,
Drop the Case test sub routine, use the MidStr() ,the QEI will be a string variable,, when you have parsed it out convert to numeric if you intend doing maths on it.
ie: after parsing the QEI section, try nQEI = #QEI. ; dont forget to dim nQEI as a Word
E
jjw
Joined Dec 24, 2013
823
Hi E,
C.
Hi
The syntax in the picture is wrong.
The correct is string1=Midstr( string2, n1, n2 )
which extracts n2 characters from string2 starting at position n1.
camerart
Joined Feb 25, 2013
3,853
Hi
Hi E and J,
Firstly can I clarify what $SENTENCE is coming from the 18F4431.
Here is the QEI section from the program and a terminal view of the TX DATA signal.
Is this ok?
The use of 'n' numbers is a bit confusing, would it be possible to use the actual sentence words please?
C
get_count:
Toggle yled
WaitMs 300
qeideg.LB = CAP2BUFL
qeideg.HB = CAP2BUFH
While SSPBUF = 0
Wend
If SSPBUF = qeideglb Then
SSPBUF = qeideg.LB
Else
If SSPBUF = qeideghb Then
SSPBUF = qeideg.HB
Endif
Endif
Hserout "$QEIDEG", ",", #qeideg, ",", CrLf
Goto get_count
ericgibbs
Joined Jan 29, 2010
21,606
hi C,
I mistyped some info in an earlier post!:(
It should have read:
QEIDEG= MidStr(msg,9,3)
Where a typical String msg = $QEIDEG,123,?
So the QEIDEG value is a String = '123'
Do you follow OK.?
E.
It would be easier to follow if you chose a different 'name' for the variable eg: Deg= MidStr(msg,9,3)
eg: clip from your last post:
camerart
Joined Feb 25, 2013
3,853
hi C,
Do you follow OK.?
E.
Hi E,
I changed [ QEIDEG= MidStr(msg,9,3) ] to [ QEIDEG= MidStr(msg1,9,3)
This didn't produce anything for QEIDEG in the variables in SIM.
C
get_valq: '$QEIDEG,???,?
Select Case csv 'COMMA POSITION VALUES
Case 2
QEIDEG = MidStr(msg1, 9, 3)
Case Else
EndSelect
msg1 = ""
Return
ericgibbs
Joined Jan 29, 2010
21,606
hi C,
You should not use the Case Statement for testing just one comma value.
Use only a single line in your Code, no gosubs or returns required
QEIDEG = MidStr(msg1, 9, 3) ' assuming the msg1 = $QEIDEG,123,?
This will give a String value of QEIDEG
E
camerart
Joined Feb 25, 2013
3,853
hi C,
E
Hi E,
It didn't work, so I tried changing the numbers, and leftstr/rightstr, and saw numbers in the QEIDEG variable, but as before they dissapeared, ending with the '?'
I wonder if this section has anything to do with the problem? It chooses which of the $SENTENCES to Parse.
C.
csv = 0
For txi = 1 To rxin
char = str1(txi)
strchr = Chr(char)
If strchr <> "," Then
msg1 = msg1 + strchr
Else
csv = csv + 1
If str1(1) = "Q" Then
Gosub get_valq 'QEI4431
'SET DATASWITCH: 'C/S S0=L S1=L =TX4431, S0=H S1=L =HC-12, S0=L S1=H =GPS
dataswitch_S0 = 1 'Set to next in sequence: REMOTE
dataswitch_S1 = 0
rled = 1
yled = 0 'REMOTE
Endif
If str1(1) = "R" Then
Gosub get_valr 'REMOTE
dataswitch_S0 = 0 'Set to next in sequence: GPS
dataswitch_S1 = 1
rled = 0
yled = 1 'GPS
Endif
If str1(5) = "C" Then
Gosub get_valg 'GPS
dataswitch_S0 = 0 'Set to next in sequence QEIDEG 4431
dataswitch_S1 = 0
rled = 0 'QEIDEG
yled = 0
Endif
Endif
Next txi
camerart
Joined Feb 25, 2013
3,853
hi,
Back to the QEIDEG topic, try this Parsing1.bas program.
E
Hi E,
With this program the Hardware UART stops at'$' and LOOPs quickly around the two RED lines.
C.
If msgflg = 1 Then 'intr has read the GPS msg into arrays
Disable High
Hserout "Incoming msg1= "
Hserout rxinp
Hserout CrLf, CrLf
Hserout "Parsed String= "
deg1 = MidStr(rxinp, 9, 3) 'get the degree part of the msg1
Hserout deg1, CrLf, CrLf
wdeg1 = StrValW(deg1) 'convert to word variable
Hserout "Numeric Degs= "
Hserout #wdeg1, CrLf
rxinp = ""
msgflg = 0
Enable High
Endif
Goto main
camerart
Joined Feb 25, 2013
3,853
I've been trying to get the DATA SWITCH to work, but So far I've failed :(
I tried a simple continuity test on the 2x dataswitch_S*, and found dataswitch_S0 shorted to GND.
Here is the bottom of the PCB showing the link, once cut it now works.
Here is a terminal view of the 18LF4620 RX PIN.
C
camerart
Joined Feb 25, 2013
3,853
hi,
E
Hi E,
I tried [ Parsing1 ] but had difficulty transposing the varable, but I did get the QEIDEG to parse another way. I think I SENT the DECIMAL, then RECEIVED it.
I'm not getting 0 to 359 Degrees, but the 2x BYTES added together incorrectly. I'll come back to it later, as I'm testing the REMOTE signal/DATASWITCH.
C
camerart
Joined Feb 25, 2013
3,853
hi,
Show how you are trying to add the bytes.
E
Hi E,
This is a section from the 18F4431 BASE PIC. QEI READ
c
get_count:
Toggle yled
WaitMs 300
While SSPBUF = 0
Wend
SSPBUF = qeideg.LB
Else
SSPBUF = qeideg.HB
Endif
Endif
WaitMs 10
'qeideg.LB = 100
'qeideg.HB = 1
'Hserout "QEIDEG.LB", ",", #qeideg.LB, ",", CrLf
'Hserout "QEIDEG.HB", ",", #qeideg.HB, ",", CrLf
Goto get_count
camerart
Joined Feb 25, 2013
3,853
hi C,
Run this demo program, it shows how to use the convert.
E
Hi E,
I think I have it set to your suggestion, but it counts 0 to 359 4X in one revolution of the knob.
I remember that there is a setting in the D/S and old programs, to correct this, and I'm now checking.
Thanks,
C.
camerart
Joined Feb 25, 2013
3,853
I'm still trying to get [ $QEIDEG,123? ] to parse properly.
Here is the program: (Warning it takes a long time to simulate)
With the Hardware UART, Copy and past [ $QEIDEG,123? ] and it will report '123' (See variables)
In real life there is a DATASWITCH with 2x select inputs 'dataswitch_S0' and' dataswitch_S1' (See variables)
S0=0 S1=0 then input $QEIDEG,123?
S0=1 S1=0 then input $REMOTE,5,7,9,?
S0=0 S1=1 then input $GPRMC,123519,A,4807.038,N,01131.000,W,022.4,084.4,230394,003.1,W*6A?
If $GPRMC,123519,A,4807.038,N,01131.000,W,022.4,084.4,230394,003.1,W*6A? is first then $QEIDEG,123? adds digits.
Anyone know how to correct this please?
EDITED
C.
camerart
Joined Feb 25, 2013
3,853
If anyone is trying the above simulation, you may also notice that: Gosub get_valq 'QEI4431 does not RETURN to Gosub get_valq 'QEI4431
Any ides what's happening, and how to correct it please.
C.
For txi = 1 To rxin 'rxiCCCCCCC
char = str1(txi)
strchr = Chr(char)
Else
csv = csv + 1
dataswitch_S1 = 0
rled = 1
yled = 0 'REMOTE
Endif
dataswitch_S1 = 1
rled = 0
yled = 1 'GPS
Endif
Gosub get_valg 'GPS
dataswitch_S1 = 0
rled = 0 'QEIDEG
yled = 0
Endif
Endif
Next txi
