Remote control by location (PIC in Oshonsoft)
ericgibbs
Joined Jan 29, 2010
21,550
Morning C,
Which programs are you referring too.?
I thought we were going to focus on just getting the HW SPI test running on the 4620 and 4431.??
Then you post it, so that I can upgrade the data being transferred.
E
camerart
Joined Feb 25, 2013
3,847
Morning C,
E
Morning E,
To clarify:
In post #349 https://forum.allaboutcircuits.com/...ve-pics-using-spi-in-oshonsoft.156175/page-18
the image shows the result of the 18F4620 and 4431 programs working on my PCB, and exchanging happily.
Next to integrate my MAIN programs that work with the peripherals. The results of the 18F4620, shown on this thread at #428. And the 18F4431 I had previously got working with the INCREMENTAL ENCODER.
While integrating, I got mixed up and have to right back to all of the originals and try again. (Lets hope I get it right this time:))
EDIT:
C.
camerart
Joined Feb 25, 2013
3,847
OK,,
So please post your HW SPI Master and Slave test programs.
Hi E,
Here are the 2x programs, plus an analysis.
Unfortunately they have stopped talking to each other.
Note; I started again, so I must have made a mistake:(
C.
ericgibbs
Joined Jan 29, 2010
21,550
hi,
Downloaded your programs, will check later.
The logic analyser waveforms are not really helpful.:(
I suggest you use the UART for monitoring and posting the data.
E
camerart
Joined Feb 25, 2013
3,847
hi,
E
Hi E,
I found the latest programs, but if you recall [ CR ] wasn't accepted by Oshonsoft, so I changed it to [ CRTN ] now this isn't accepted, so I've changed it to [ CARTN ] which is accepted.
I'm sure these programs worked at one time, but today they don't.
I've attached the Analysis, the C.S.V. and the terminal output.
EDIT: A previous post regarded the importance of the SLAVE running faster than the MASTER. I can add a XTL, then switch on 4xPLL if this is a good idea.
C.
ericgibbs
Joined Jan 29, 2010
21,550
hi,
The csv file shows SPI data OK.????
Are you using a xtal on the 4620, you have HS set in the CONFIG header, if yes, waht is the xtal frequency.
Otherwise the two progs are identical with the ones I posted, with exception of the pin assignment.
E
camerart
Joined Feb 25, 2013
3,847
hi,
E
Hi E,
The 18F4620 is running on an 8Mhx Crystal, as shown in the title also the CONFIG1H comment.
Can you guess what may be wrong to cause the messages to stop swapping?
Is it important to have the SLAVE running faster than the MASTER?
C
ericgibbs
Joined Jan 29, 2010
21,550
hi,
If they are both running at 8Mhz, as I had during the test, thats OK.
Have you made any hardware changes since you successfully ran those two programs.?
Any reason why you are not using the 4620 internal 8MHz oscillator.?
E
BTW: as you are using the latest Oshonsoft IDE's, why are you using Crlf Dim's in the Slave .?
'Cartn = Chr(0x0d) ' redundant
'lfd = Chr(0x0a)
Dim s2m As Byte
Dim m2s As Byte
Dim dta As String
msg1 = "ABCD" + Cr + Lf 'initial dummy msg
You are already doing that in the Master
Dim x As Byte
Dim y As Byte
msg1 = "1234" + Cr + Lf
msg2 = "ERIC" + Cr + Lf
Hseropen 9600
WaitMs 1000
ericgibbs
Joined Jan 29, 2010
21,550
hi,
Looking thru that csv file, the MSO and MSI seem to exchanging data ok.
If you were running my test programs, where are all the other alphanumeric characters coming from, on that csv list.??
E
camerart
Joined Feb 25, 2013
3,847
hi,
E
'lfd = Chr(0x0a)
Dim s2m As Byte
Dim m2s As Byte
Dim dta As String
Dim x As Byte
Dim y As Byte
Hseropen 9600
WaitMs 1000
Hi E,
I see your Blue and red letters, but what are you asking me to do?
I'm using a XTL on the MASTER because of some problem a long time ago, where there could have been a timing problem?
Previous sequential alpha numerics can be generated in the analyser. I've recompiled the program, and it now READs [ ERIC 1234 ]
I've added a toggling LED to the SLAVE which isn't toggling, I'll investigate.
C
ericgibbs
Joined Jan 29, 2010
21,550
hi,
These Dims are not required
'lfd = Chr(0x0a)
The Cr and Lf codes are now a part of the latest Oshonsoft compiler.
ie:
Cr ; Carriage Return
Lf ; Line Feed.
In your actual BMP program you do not require any Cr or Lf Codes, they are were only for testing using ASCII bytes,, ie: ERIC 1234 etc...
If you do include them, remember you are Writing/Reading Binary Data Bytes, which could include 0x0D and 0x0A as part of the Data group, so do not use these line terminator Codes.
I would also use the 4620 Int Osc at 8MHz.
E
camerart
Joined Feb 25, 2013
3,847
hi,
'lfd = Chr(0x0a)
ie:
Lf ; Line Feed.
E
Hi E,
Re CR LF, Do you mean as the usual [ HSEROUT "XXXX", CRLF ?
Re XTL, See: https://forum.allaboutcircuits.com/...-pics-using-hwspi-in-oshonsoft.156175/page-17 #322 for the reason I changed. I think I would have to remove the XTL for INT OSC to work, but I'm not sure. Is there a reason that you prefer the INT OSC?
C.
camerart
Joined Feb 25, 2013
3,847
Previously when converting the SWSPI to HWSPI, we used a DUMMY in each READ/WRITE, is this still relevant or is this the same as the DATA SWAP?
altmtr = 0
SSPBUF = 0xf4
While Not SSPSTAT.BF
Wend
dta = SSPBUF
WaitMs 5 '2
SSPBUF = dummy
Wend
dta = SSPBUF
WaitUs 5 '2
Hserout "F4 ", #dta, CrLf
altmtr = 1
C
ericgibbs
Joined Jan 29, 2010
21,550
hi C,
You are mixing the descriptions up, are you asking about Master <> Slave or Master to BMP
I have already covered this point, run them both at 8MHz using the internal clocks.
You had the test programs working this way, so why do you keep changing the set up.?
The code fragment in #455 is wrong, why is there a 5 milli-sec delay.?
altmtr = 0
SSPBUF = 0xf4
While Not SSPSTAT.BF ' this sends the Reg Addr 0xF4 to the BMP
Wend
dta = SSPBUF ' this is invalid data from the BMP, due to the 0xF4 Write, its not wanted in the 'dta'
'WaitMs 5 '2
SSPBUF = dummy
Wend
dta = SSPBUF ' you are now overwriting the invalid data in the 'dta' with the requested Reg data
WaitUs 5 '2
altmtr = 1
camerart
Joined Feb 25, 2013
3,847
hi C,
altmtr = 0
SSPBUF = 0xf4
Wend
'WaitMs 5 '2
SSPBUF = dummy
Wend
WaitUs 5 '2
altmtr = 1
I was referring to 2xPICs as MASTER and SLAVE. Previously, I've been naming e,g, BMP280 as MODULES, but changed to PERIPHERALS. All of the PERIPHERALS are working OK, only the 2x PIC MASTER and SLAVE weren't talking to each, now they are.
Many of your questions, refer to tests I try to find faults, when the two PICs aren't talking to each other. This is nothing to do with BMP280, that's been working ok.
True, I had both PICs running at 8MHz, but only when I added an 8 MHz XTL to the 18F4620.
As there was a fault, I questioned slight variations on the INT OSC of the 18F4431, so tried OSCTUNE at full speed, which you may guess did nothing.
As this PCB is getting tired I re-checked for whiskers and failed solder. Some where there was a problem, as it's now working.
Soon, once the rest of the PERIPHERALS, including the SLAVE working, I'll have some professional PCBs made up.
Here's a TERM view:
C
ericgibbs
Joined Jan 29, 2010
21,550
hi,
This is one of the reasons why I prefer to debug designs on bread board [ when possible] , it saves lots of time and reworking.
I guess you know that you can get adaptor PCB's for most surface mount devices.
Ref the timing, try to keep the response time of the peripheral device as fast as possible, one way is to write linear code rather than Calls to subroutines.
E
camerart
Joined Feb 25, 2013
3,847
hi,
E
Hi E,
I've edited #458 slightly.
When this project started, I used breadboards, and through the hole PICs, but since upgrading, some of the PERIPHERALS need the later chips e,g, (AK8963), so I needed to use surface mount, and moved over to SM PICs also. It has caused problems, but I used to get problems before. Remember this is now quite a complicated PCB, to wire on a breadboard:eek:
Hopefully I work in the best way I can.
C.
