Relay
BSomer
Joined Dec 28, 2011
434
I am fairly certain that the relay is wired correctly. To verify the relay is correct, remove it from the circuit and check it according to my post #22.
It is difficult to see but are you sure you soldered your wires on the sensor correctly?
Another issue is that your voltage levels are too low. You need at least 12 VDC, lower voltages will increase the current through the circuit. This could be the reason your battery is getting warm, too much current draw.
aaad2
Joined May 30, 2012
50
Hi, sorry I haven't replyed in a very long time...
I have been busy and gave up!
Now i'm back and ready to give it another go.
I bought the sensor and the soldering on their looks right.
Tomorrow I will take a picture of it and show you it. :)
kc5tpa
Joined Sep 21, 2012
48
Good, because I just got caught up on this thread, and am curious if you can make it work.
aaad2
Joined May 30, 2012
50
This circuit should work. It was verified many times by some people on this forum.
The problem might be the voltage I am using is somewhat a bit low. Furthermore, I did this on a breadboard so I am not sure if there is complete connections between the terminals.
Kermit2
Joined Feb 5, 2010
4,162
The connections in your breadboard are made of bent half hard brass. it is bent in a triangle shape with the top edges rolled over to allow you to insert the leads.
When you insert those large legged components, like large diodes and terminal pins, it will spread the brass wide. Then when you place a thin legged component, like your resistors right next to the large ones, the brass cannot make good contact on the smaller lead because it is held open too wide by the large one next to it.
Try putting thin, small leads at the far end of the row to allow for the brass clips to close somewhat with the longer distance between connection points.
aaad2
Joined May 30, 2012
50
Thanks for the help, that is probably why my batteries gets warm...
I am currently charging up the batteries again and I will be giving this another go. I have two breadboards so I will spread out the components.
Sometimes it is pretty difficult to insert one of those diodes due to the metal wire is very thick. :)
Thanks for the help/info :)
aaad2
Joined May 30, 2012
50
I will definitely finish this project! I have been busy. I will give this another go towards end of June after I have finished my exams by then. I will do what Kermit2 suggested.
The use for the relay is so that when there is movement, it can turn on by itself(I think that is what it's for anyway)
