I am fairly certain that the relay is wired correctly. To verify the relay is correct, remove it from the circuit and check it according to my post #22.
It is difficult to see but are you sure you soldered your wires on the sensor correctly?
Another issue is that your voltage levels are too low. You need at least 12 VDC, lower voltages will increase the current through the circuit. This could be the reason your battery is getting warm, too much current draw.
