found thisDo not get hung up on the pin numbers. You will find that when you order the relay you need or if you look at a datasheet of a relay, the pin numbers are really different than what you think they are.
Just look at the contacts as NO - C - NC, which is Normally Open - Common - Normally Closed. If you can identify them that way you will be in better shape.
