MisterBill2
- Joined Jan 23, 2018
- 28,273
Consider that relay contacts do not "weld closed" during the relay OPENING action. AND, a snubber or other protective scheme works to reduce sparking damage when a relay OPENS.
I researched the relay data sheet and I see an AC rating for the contacts of 3 amps. BUT, looking at the rest of the relay contact ratings, my evaluation is that those ratings are rather hard to believe.
Consider that the motor is always starting under load, both lifting and lowering the blind.
