Looking for a relay...
Externet
Joined Nov 29, 2005
2,676
Hi all.
Am after plain 120 Volt coil and either DPDT or SPDT for 120V / 20 Amperes relays/contactors. Perhaps even SPST. Found several in the market, some with too long delivery time, some at a price I do not want to pay for a hobby application.
As I have access to maaany canibalizable equipment; would like to know your suggestions on which may use these in order to salvage.
Air conditioning seems are mainly 230V coil. Microwave ovens are not 120V coil. Air handlers sequencers neither. Where would you look at ?
Hi all.
If your application doesn't absolutely require a 120 VAC coil, it may be easier and cheaper to salvage a 24 VAC HVAC contactor and power its coil with a small 120 to 24 VAC control transformer. You can salvage one from an outdoor central air conditioner or heat pump condensing unit.
Externet
Joined Nov 29, 2005
2,676
Thank you. Relay/contactor coil 120VAC or 120VDC. Contacts 120VAC or 120VDC. Normally closed contacts will handle AC mains, normally open will handle DC and no arcing is to be prevented.
Common C contacts to feed a 1500W 120V AC or DC space heater; N.O. to 120VAC mains; N.C. to 120VDC solar array. Coil terminals to 120VDC solar array
