Bordodynov
- Joined May 20, 2015
- 3,431
My function is to compare and produce an output, whereas one pin will sense the voltage present at instant and give(for eg Vout should be high if the voltage is <3.9 and Vout should be low if Vout is greater than 4.3)
Crutschow thanks for ur help and support.Here's the LM339/393 circuit modified with a TL431 reference configured as a series regulator to provide constant 5V power to the circuit.
The LTspice simulation shows the output going low at an ECO voltage of 2.68V and high at 2.33V with each transition delayed about 1 second, for both 12V and 24V power.
Is that what you wanted?
could you help me in getting model files for Altium designer?Here's the LM339/393 circuit modified with a TL431 reference configured as a series regulator to provide constant 5V power to the circuit.
Sorry, I'm not familiar with Altium designer.could you help me in getting model files for Altium designer?
