That's great, Sounds like that gate is definitely the culprit and with a little luck, changing IC8 will give you a working 'scope. In my experience, equipment that uses discrete components and basic logic gates is fairly easy to get working. Its the later stuff, with programmable bits you don't have visibility of that are difficult to fix. Mind you, 95% of faults on modern day kit like phones, iPads, etc are failed multi-layer ceramic capacitors (MLCC) shorting across one or other supply rail. Very easy to find with voltage injection and a thermal camera.Then I used a 2K resister from /CONT to gnd to dissipate the voltage and it came close to 0V. The buttons came response which is great but after powering off it doesnt remember the settings. So I got ahead of myself and ordered 2 of these nand IC's in so i have a spare in case it happens again.
