Powering a relay from a siren sounder
sghioto
Joined Dec 31, 2017
8,758
I feel that just a basic circuit like this is worth starting with unless I'm missing the obvious, sorry about my drawing!
Just noticed but from that drawing it appears you are trying to power the relay coil directly through the OC. That's not ever going to work as the relay coils draws appx 75ma.
Pcarmour
Joined Jun 24, 2023
105
Hi Sghioto,
Thank you, you had it exactly right!
I followed your circuit with the 10K but nothing so changed it to 47K and I have a triggered relay!!! Perfect!
The relay draws 3ma while idle which, no doubt, will reduce battery life slightly but I can address that if it becomes a problem.
This has been my third request for help on this forum and each time I have had amazing effort from its members, solved issues and learnt so much. I will, no doubt, will find something new to ask for help with and know this is the place to come.
Thank you again and everyone else who contributed.
Peter
28,499
This is a photo of the inside of the siren unit. Does this match your alarm?
Read everything you see on sounder.
Should be possible to connect directly across the sounder to access a voltage to drive a mosfet or relay circuit.
I just saw this thread this morning. The text that we see part of on the back of that black sounder package will tell us exactly what the voltage feeding it is, and then it will be simple to creat a circuit to interface it with.
Pcarmour
Joined Jun 24, 2023
105
Hi Sghioto,
Peter
