Powering a relay from a siren sounder
Audioguru again
Joined Oct 21, 2019
6,826
A reading of 29VAC on most multimeters is actually 200V or more since most multimeters are made to accurately measure 50Hz or 60Hz. The sounder probably is driven with and produces 3kHz.
Many multimeters do not accurately measure a sinewave or a squarewave. An oscilloscope like I said will measure them fairly accurately.
sghioto
Joined Dec 31, 2017
8,758
That will work for the 5 volt relay module. Can you post a close up HD photo of the pc board inside the siren unit?
There maybe better sources to use to activate the relay module.
Pcarmour
Joined Jun 24, 2023
105
Thank you for your help and comments
I think I’ll try a 2 diode, half wave rectifier and see what voltage I get. Hopefully it will be enough to power the 5v normal relay otherwise I’ll go for a 4 diode bridge and see if that works.
Audioguru again
Joined Oct 21, 2019
6,826
If the sounder is piezo then its driving current is too low to drive a 5V mechanical relay coil.
A Mosfet can drive the relay if you attenuate its gate voltage enough.
sghioto
Joined Dec 31, 2017
8,758
Can't really tell from the photo.
1/2 wave rectifier should only need 1 diode. Pretty sure the relay module is going to load the sounder too much.
Is this circuit you have in mind?
sghioto
Joined Dec 31, 2017
8,758
That relay module draws 75 ma when activated. It doesn't make any difference if you use the 6 volt battery to power the relay module or voltage from the sounder as the current required is the same and that is supplied by the battery. I'll draw up the circuit I think is needed here shortly.
Pcarmour
Joined Jun 24, 2023
105
That would be very good of you, thank you.
