Powering a relay from a siren sounder
sghioto
Joined Dec 31, 2017
8,758
So? Does that make my statement incorrect somehow?
It does in reference to working in the circuit as shown in post 36.
However this circuit might work if the sounder is configured as shown.
Several more voltage measurements from the TS will confirm and may provide other options.
Pcarmour
Joined Jun 24, 2023
105
Thank you, I can see how this will trigger the relay but I have an observation. The positive to the sounder also comes from the driver circuit and I expected to use this positive side to the IN.
Pcarmour
Joined Jun 24, 2023
105
I feel this is exactly the circuit required, I see the LTV814 has a diode with the LED which I assume does the rectifying. I’m buying a LTV814 now.
Thank you.
Peter
Question, what is the requirement for the1N4001 diode on the positive to power the relay?
Peter
sghioto
Joined Dec 31, 2017
8,758
You may not need the PC814 if you can get me a few voltage measurements.
Diode is to drop the voltage to appx 5.3 volts for the relay module.
Pcarmour
Joined Jun 24, 2023
105
I’ve bought the PC814 as I do like the way it isolates the relay on both the + and - sides. I will try the relay supply from the batteries (6v) which may be lower with the circuit and sounder drain once triggered. If I can, I have a PC oscilloscope on an old notebook which I’ll connect up and get some data and the wave, I’d like to use it after a very long time.
Pcarmour
Joined Jun 24, 2023
105
Well I’ve managed to get something, not sure what it’s saying but here’s a screenshot from my notebooks oscilloscope. Hope it gives you some information. IMG_0200.jpeg
BobTPH
Joined Jun 5, 2013
11,665
I have a bad feeling about this. Driving and LED or opto coupler is likely to have a large effect on the transducer. I suspect we are going to need amplification.
sghioto
Joined Dec 31, 2017
8,758
For a test place a 10K resistor across the sounder and measure the voltage when activated. Want to see if that loads the sounder too much.
Pcarmour
Joined Jun 24, 2023
105
As I have already bought the optocoupler I’m going to wait until it arrives and see if it works. I think I’ll try your circuit as in post 36 unless you have any modifications.
Thank you for your help and time.
Peter
